Dynamic Block Insertion and Use
Save the attached dynamic block somewhere. Load and run the program "dropin". I run it in a clean, empty, new drawing. Pick the block from your computer. Dropin will insert the block 3 times. Watch the screencast of the dynamic block error. Do you get the same result?
I select the block to highlight the grips. I use a stretch grip to stretch the block. The block looks horrible. Lines are partially stretched or not stretched at all. So I leave it highlighted and type "bedit" at the command line. I enter block editor - I've learned that I have to change something no matter how small or insignificant. I've learned that all I have to do is change the zoom, so I give my scroll wheel a little 'flick'. Then I exit the block editor, saving changes. When it goes back to the drawing, the block has repaired itself and looks correct.
This has been going on for about 5 years that I'm aware. I've tried a "resetblock" command after inserting it. I've tried regens. I recently read a post that said "You can't use the basepoint parameters in dynamic blocks. They're broken, they don't work." I looked and had basepoints, so I deleted them. But that doesn't look like that was it. I suspect there's a bug in vla-insertblock. Does anyone have an AutoLISP routine that replaces that command? I need the function of that command, I need to be able to insert the block onto any space: Model Space, any Paper Space tab, etc.
Anyone have a solution? I don't know if there's an error in the block, or the code. I started typing this into the "Bug" forum, but stopped because if you insert the block manually it works fine. Seems like something I don't understand in the code. Thanks in advance. Sorry if I formatted anything wrong. (Is there a particular way to attach a screencast?
Screencast: https://autode.sk/2XP7nQj
(DEFUN c:dropin	(/	A      BLOCKNAME     I#	   INDEX
		 OCA	OCN    PT     S#     T1	    TEXT   TOTMODS
		 VOBJECT       X
  (vl-load-com)
  (setq	oca	  '((18 18 18 18) (18 18 18 18 19) (17 17 17 17))
	INDEX	  1
	T1	  NIL
	pt	  '(0 0)
	BLOCKNAME (getfiled "Select Block" "" "dwg" 16)
	oca	  '((19 19 19 19) (18 18 18 18) (19 19 18 18))
	ocn	  '((1) (2) (3))
  )					;SETQ
  (FOREACH A OCA
    (SETQ vobject
		  (vla-insertblock
		    (vlax-get-property
		      (vla-get-activedocument (vlax-get-acad-object))
		      'modelspace
		    (vlax-3D-point (trans pt 1 0))
		    blockname
		    1.0
		    1.0
		    1.0
		    0.0
	  INDEX	  1
	  text	  nil
	  totmods 0
	  i#	  (car (nth (vl-position a oca) ocn))
	  s#	  1
    )					;setq
    (mapcar
      '(lambda (x)
	 (if (= "Lookup1" (vla-get-propertyname x))
	   (vla-put-value
	     x
	     (vlax-make-variant
	       (length A)
	       (vlax-variant-type (vla-get-value x))
      (vlax-invoke vobject 'getdynamicblockproperties)
    (FOREACH B A
      (SETQ TEXT    (APPEND TEXT
			    (LIST (CONS	(STRCAT	"STRING"
						(ITOA (- (length A) 3))
						(ITOA INDEX)
					(STRCAT	"INV"
						(if (= (strlen (itoa i#)) 1)
						  (strcat "0" (itoa i#))
						  (itoa i#)
						"S"
						(if (= (strlen (itoa s#)) 1)
						  (strcat "0" (itoa s#))
						  (itoa s#)
						(itoa b)
	    INDEX   (1+ INDEX)
	    totmods (+ totmods b)
	    s#	    (1+ s#)
      )					;SETQ
    )					;FOREACH
		       (LIST (CONS "SUB-ARRAY-LINE-1"
				   (strcat "("
					   (itoa totmods)
					   ") BOB'S AWESOME MODULES"
	  TEXT (APPEND TEXT
		       (LIST (CONS "ES#"
				   (strcat (ITOA (1+ (CADR A)))
    )					;setq
    (mapcar
      '(lambda (x)
	 (if (assoc (vla-get-tagstring x) text)
	   (vla-put-textstring
	     x
	     (cdr (assoc (vla-get-tagstring x) text))
      (vlax-invoke vobject 'getattributes)
    )					;mapcar
    (SETQ PT (POLAR PT (* PI 1.5) 3)
)					;dropin
2DED 1-Line Array.dwg
Hmm, that's a first for me. For all the times I've used vla-insertblock, it never glitches like that. Quite funny.
Edited by Jonathan Handojo
paste your block into Bcad just normal block not DB. only 1 grip: Insertion point. no others stretch grips etc..
or incompatible? (some members still using <2010)
not sure, try vla-update
I might be missing something, but you have 2 oca variables in first (setq)... What do you want to achieve with this?
Now that I looked at your screencast I understand what is the problem... You probably typed oca twice for testing purposes...
Haven't tested your code with your attached Dynamic block, but I see it in screencast. However I don't know what could be the thing that's causing problem with stretch action in newly insertions of DB...
If it will make you feel better and on my testings A2018 it bahaves exactly like in your screencast - there is some kind of bug... Still I've checked your code and it looks good to me, I only changed one line in portion where you change "Lookup1" value... I don't know much with DB, but here is my revision although it's all in vain and with unpredicted symptoms.
(DEFUN c:dropin ( / BLOCKNAME I# INDEX OCA OCN PT S# TEXT TOTMODS VOBJECT )
  (vl-load-com)
  (setq INDEX        1
        pt           '(0 0)
        ocn          '((1) (2) (3))
  )                                        ;SETQ
  (FOREACH A OCA
    (SETQ vobject
                  (vla-insertblock
                    (vlax-get-property
                      'modelspace
                    blockname
                    1.0
                    1.0
                    1.0
                    0.0
          INDEX   1
          text    nil
          totmods 0
          s#      1
    )                                        ;setq
    (mapcar
      '(lambda ( x )
           (vla-put-value
             x
             (nth (length A) (safearray-value (variant-value (vla-get-allowedvalues x))))
    (FOREACH B A
                                                (ITOA INDEX)
                                        (STRCAT "INV"
                                                  (itoa i#)
                                                "S"
                                                  (itoa s#)
                                                (itoa b)
            INDEX   (1+ INDEX)
            s#      (1+ s#)
      )                                        ;SETQ
    )                                        ;FOREACH
                                   (strcat "("
                                           (itoa totmods)
          TEXT (APPEND TEXT
                       (LIST (CONS "ES#"
    )                                        ;setq
    (mapcar
      '(lambda ( x )
           (vla-put-textstring
             x
    )                                        ;mapcar
    (SETQ PT (POLAR PT (* PI 1.5) 3))
)                                        ;dropin
Like you suspected, you were right... The problem was (vla-insertblock)... I've retested and now everything worked as desired with this revision :
(DEFUN c:dropin ( / *ERROR* BLOCKNAME I# INDEX OCA OCN PT S# TEXT TOTMODS VOBJECT ATTR )
  (vl-load-com)
  (defun *error* ( m )
    (if attr (setvar 'attreq attr))
    (if m (prompt m))
  (setq INDEX        1
        pt           '(0 0)
        ocn          '((1) (2) (3))
  )                                        ;SETQ
  (setq attr (getvar 'attreq))
  (setvar 'attreq 0)
  (FOREACH A OCA
    (SETQ INDEX   1
          text    nil
          totmods 0
          s#      1
    )                                        ;setq
    (vl-cmdf "_.-INSERT" BLOCKNAME "_S" 1.0 "_R" 0.0 "_non" pt)
    (setq vobject (vlax-ename->vla-object (entlast)))
    (mapcar
      '(lambda ( x )
           (vla-put-value
             x
    (FOREACH B A
                                                (ITOA (length A))
                                                (ITOA INDEX)
                                        (STRCAT "INV"
                                                  (itoa i#)
                                                "S"
                                                  (itoa s#)
                                                (itoa b)
            INDEX   (1+ INDEX)
            s#      (1+ s#)
      )                                        ;SETQ
    )                                        ;FOREACH
                                   (strcat "("
                                           (itoa totmods)
          TEXT (APPEND TEXT
                       (LIST (CONS "ES#"
    )                                        ;setq
    (mapcar
      '(lambda ( x )
           (vla-put-textstring
             x
    )                                        ;mapcar
  )                                          ;foreach
  (*error* nil)
)                                        ;dropin
HTH., M.R.
I'm not familiar with vla-update. I can't seem to find documentation on it. I'll continue to look into it.
I was hoping for a revelation here, I have it on the autodesk forum as well. This has been going on for me for 5 years. One thing I tried this week seems to work-around. And for all the bugs I find, a quick work-around is good enough for me. I said I tried the "resetblock" and thought it was working but recently found out that it was not. Here's the flow I tried previously:
vla-insertblock
(command "resetblock" (entlast) "")
set dynamic block properties
populate attributes
Here's what I tried that seems to work:
vla-insertblock
populate attributes
Yeah, I had to set the properties twice. But here's another oddity. On the last block that's inserted & messed up, this doesn't work. So what I did was wrote a little routine that:
get dynamic block properties
"resetblock"
set dynamic block properties back with the ones I just got
I run that routine at the exit of the program, and inside my error trap program in case someone escapes out. That seems to clear this up. In my own testing it works. But I haven't yet given it out to my co-workers for use. So we'll see if that's a fix.
