My issue is when I’m drawing in model space with a 2-viewport screen for drawing electrical 3D; one viewport is plan view and the other in a S.W. Iso. When I toggle back and forth between the views they reset themselves back to plan view. Is there a setting to lock the view ports to keep the view of your choice?
Thanks in advance!
You need to set UCSFOLLOW to 0. This variable needs to be set in each viewport, so activate a viewport, type UCSFOLLOW and change the setting to 0. do this for each viewport.
