I'm trying to learn Autolisp.
I using Reinaldo N. Togores book "AutoCAD expert's Visual LISP".
One of his lisp programs, is a Function called "Draw-Text"; which asks for a insertion point, then places text and that point.  I can't get it to work.
Textstyle should be set to "Standard"
Here is the code:
;;;Generic text-drawing function.
(defun draw-text (pt-ins height numbering / old-osm)
  (setq old-osm (getvar "OSMODE"))
  (setvar "OSMODE" 0)
  (command "._TEXT" pt-ins height "" numbering)
  (setvar "OSMODE" old-osm)
) ;_ end of defun
And this is the expression to check if it is working
(draw-text (getpoint "Insertion Point: ") 5.0 "TEST")
When I run the program I get    Unkown commarnd "TEST"
Any help would be appreciated.
Thanks
That example relies on the active Text Style having a text height set to zero.
Edited by Lee Mac
It is a problem with creating text like as lee has stated that depending on the text style it can have a height. Will try to find my workaround. At my last workplace it was enforced "Standard" was just that do not change. If you want something else make a new style.
