Split Table between sheets? ie: Long table on multiple sheets?
Vanilla Autocad 2020.
I have split a table and want to move the "second table" to another sheet.
Is this possible?
Could someone please explain the process?
Any best options for splitting a long table across multiple sheets?
Also, is dragging the bottom caret at the table the only way to split the table?
Inventor allows you to pick a line in the table, RMB and pick Table Split.
Didn't know if Autocad has a similar option..
Thank you!
Edited by ILoveMadoka
Using viewports?
Is that the only way to split a table across multiple sheets?
25 minutes ago, ILoveMadoka said:
Using viewports?
That's the only way I can think to do it without the risk of overlooking rows (by creating a separate table on each sheet).
I think the viewport option will have to do.
Come on Autodesk!
If you can split a table and move it easily in Inventor
It's not unthinkable to add the same functionality into Autocad!
You want like excel hide option but effective only in a viewport and can be different per viewport. It takes seconds to make a view port and viewports can sit on top of each other.
 Share
