Create Hose Inventor Hose Runs
sjordash
Hi,
I am running flexible hoses in Inventor and can’t get the routes correct and  am wondering if someone could help me find a video I watched once on creating pipe / tube runs. It was runs through a building using brackets / points and it also described a proprietary design of a “cube tool” to use to define points to run the pipes through. You could use the cube to change the run direction, and I think it was from someone like TEDCF.
Thanks
