sjordash Posted May 8, 2020 Share Posted May 8, 2020 Hi, I am running flexible hoses in Inventor and can’t get the routes correct and am wondering if someone could help me find a video I watched once on creating pipe / tube runs. It was runs through a building using brackets / points and it also described a proprietary design of a “cube tool” to use to define points to run the pipes through. You could use the cube to change the run direction, and I think it was from someone like TEDCF. Thanks Quote Link to comment Share on other sites More sharing options...
