DWF paper color
Hi,
need help on this: every plot i do in Autocad 2009, when oppened in Autodesk Design Review or in DWF Viewer, has it´s paper (background) in some sort of pink instead of white.
The layout from which the plot is originated has its backgroud white and the plot preview also shows the white background, but the plot... pink.
HELP!!!
Hi There, Open Design Review. Go 'Tools', 'Options" and then click on the 'Sheet' tab and under 'Paper Settings', change the colou to white. Hope this helps.
Hi,
that doesn't do it. Usualy, by default, the paper color is white. That way i'll only force white in the machine that i'm using to see the DWF. Problem is that i'm handling a large DWF repository and the drawings ploted by autocad 2008 are displayed with paper in white, the ones ploted with 2009 are displayed in pink. Many people have access to the repository and they can´t access the options in DWF viewer or Design review.
Maybe the version i have is the female version:lol: :lol: :lol: , pretty in pink!!!
Hi,
adding assault to injury: when in plotter configuration, custom properties, additional output settings, background color shown in viewer, everysingle color that i choose, but black, always appears as other color in viewer. For instance, when i choose green i get a nice yellow.
The only one that i get right is black.
Help!!!
Are there any other machines with 2009? Try creating the DWF with them. If the problems is isolated to your machine you can try a repair of the AutoCAD software.
Hi,
unistalled the whole package and installed it again. Same result.
HELP!!!:? :? :?
Hi,
problem solved, uninstalled 2009 x64, installed 2008 x64 version on the same machine and i finally can plot in white paper.
It seems like a bug on the x64 autocad 2009 version to me.
