All,
setpropertyvalue
I am trying to use the above function to manipulate viewport overrides for layers.
It works as expected with the following layer property names:
"ColorOverride"
"IsFrozenInCurrentViewport"
"TransparencyOverride"
However, I cannot successfully apply values to the layer property names below:
"LineWeightOverride"
"LinetypeObjectIdOverride"
I am able to successfully retrieve values for the above using the getpropertyvalue function but I cannot apply properties.
Examples:
(setpropertyvalue (tblobjname "LAYER" "TEST-LAYER") "LinetypeObjectIdOverride" "BORDER"))
returns: "error: ADS request error"
(setpropertyvalue (tblobjname "LAYER" "TEST-LAYER") "LineWeightOverride" 15)
returns: "Lineweight rounded to nearest valid value of 2.11 mm"
It works as expected only for values of 0 and 1. All other valid lineweight values are either rounded up to  2.11 or down to 0.0. For example, it will not accept 13 or 1.3.
Can anybody shed any light? Any guidance would be much appreciated.
Cheers..
Edited by abra-CAD-abra
9 hours ago, abra-CAD-abra said:
All,
setpropertyvalue
"ColorOverride"
Examples:
Cheers..
You are value you are supplying is incorrect
When you (dumpallproperties) you get
LineWeight (type: AcDb::LineWeight)  (LocalName: Lineweight) = -3
LineWeightOverride (type: AcDb::LineWeight)  (LocalName: Viewport Lineweight) = Failed to get value
and
LinetypeObjectId (type: AcDbObjectId)  (LocalName: Linetype) = 7ffff603960
LinetypeObjectIdOverride (type: AcDbObjectId)  (LocalName: Viewport Linetype) = Failed to get value
"Border" is a linetype "name" NOT an objectID
and I suspect that the same is true for lineweight
accepted Lineweight constants
acLnWtByLayer
acLnWtByBlock
acLnWtByLwDefault
acLnWt000
acLnWt005
acLnWt009
acLnWt013
acLnWt015
acLnWt018
acLnWt020
acLnWt025
acLnWt030
acLnWt035
acLnWt040
acLnWt050
acLnWt053
acLnWt060
acLnWt070
acLnWt080
acLnWt090
acLnWt100
acLnWt106
acLnWt120
acLnWt140
acLnWt158
acLnWt200
acLnWt211
Dlanorh had a similar problem, can see the mixture of numbers, strings and known names.
(vlax-for ent block
(vla-put-color ent 0)
(vla-put-linetype ent "Bylayer")
(vla-put-lineweight ent aclnwtbyblock)
Guys, thank you for your responses.
When I dump all properties for Layer "0" inside an active viewport, it returns the following:
LineWeightOverride (type: AcDb::LineWeight)  (LocalName: Viewport Lineweight) = 100
LinetypeObjectIdOverride (type: AcDbObjectId)  (LocalName: Viewport Linetype) = 216decd3960
The return value for the LineWeightOverride property is 100 which is 1.00mm.
Similarly;
(getpropertyvalue (tblobjname "LAYER" "0") "LineWeightOverride" 1)
returns 100.
If the VP Lineweight was 1.3mm it would return 13. I cannot assign a value of 13 using:
(setpropertyvalue (tblobjname "LAYER" "0") "LineWeightOverride" 13)
It returns "Lineweight rounded to nearest valid value of 2.11 mm"
For LinetypeObjectIdOverride:
I can retrieve the name of the linetype using:
(setq val (getpropertyvalue (tblobjname "LAYER" "0") "LinetypeObjectIdOverride"))
(setq ltn (getpropertyvalue val "Name"))
This returns "Continuous"
However, I cannot set this value using:
(setpropertyvalue (tblobjname "LAYER" "0") "LinetypeObjectIdOverride" "Border")
How do I access the objectID?
The arguments for setpropertyvalue are as follows:
(setpropertyvalue ename propertyname value [or collectionName index name val])
(vlax-for ent block
BIGAL, the above vla-put functions don't work for vieweport overrides. You would expect those functions to cater for all.
Have you tried :
(setpropertyvalue val "Name" "Border")
I have to ask this, but I hope you are trying to run viewport overrides whilst looking at modelspace through an active paperspace viewport.
On 6/12/2020 at 4:30 PM, marko_ribar said:
Have you tried :
Yes. This also returns: ADS request error
Yes
