I am trying to set a variable with distance between 2 points. I am getting 2 points from user input but when I try to convert to feet (2nd line of code)
I am getting an error.  I cannot figure out what is wrong with this:
(setq distpcc (rtos(distance pt1 pt2) 2 8))
(setq distpcc2 (/ distpcc 12 ))
Thanks
Edited by Tbag
If you could post your whole code, that would be helpful.
Something like this maybe?
(defun c:ttt (/ P1 P2 Z1 Z2)
    (setq Pt1 (getpoint "\nSelect First Point"))
    (setq Pt2 (getpoint "\nSelect Second Point"))
    (setq Z1 (nth 2 Pt1))
    (setq Z2 (nth 2 Pt2))
    (setq VAL (rtos (- Z1 Z2)))
I would like to divide distpcc variable in (setq distpcc (rtos(distance pt1 pt2) 2 8))  by 12
so I added (setq distpcc2 (/ distpcc 12 ))
but It does not work. Is it because distpcc is a string and it is not a real number?
Thanks,.
;Original Code:
;Just dont convert it to a string, do the following.
(setq distpcc2 (/ (distance pt1 pt2) 12.0))
;Also you should use decimal when dividing
;Test the following
(rtos (/ 1 12) 2 8)
;versus
(rtos (/ 1.0 12.0) 2 8)
Edited by Hippe013
Simply put, you cannot perform an arithmetic function on a string stype value.
Unless of course you are working on some other programming language where the symbol  "+" also means concatenate.
On 6/16/2020 at 3:26 PM, Hippe013 said:
;Original Code:
;Test the following
(rtos (/ 1 12) 2 8)
;versus
Thanks so much, very helpful.
Thanks. makes sense.
