Turn off termporarily snap during matchrpop progress
Hello everyone,
I need to deactivate thru Autolisp temporarily snap when using "matchprop" command, because we have big drawings and snap freezes autocad in the process.
F3 does not work in this case because it is very easy to forget to do it before using the command and restore it later. I am looking for specifically a routine that does it automatically.
Any suggestion?
thanks in advance
(defun c:SnapO (/ SnapOnOff)
(setq SnapOnOff (getvar "osmode"))
(if (< SnapOnOff 16384)
(setq SnapOnOff (+ SnapOnOff 16384)) ;osnap off
(setq SnapOnOff (- SnapOnOff 16384)) ;osnap on
);end if
(setvar "osmode" SnapOnOff)
);end
Or just set snap to what you want in your code, often I will do multiple osmode's to suit in a code sequence like mid then end 2 & 1
(setq oldsnap (getvar 'osmode)) ; get current snap setting
(setvar 'osmode 0)
.......your code
(setvar 'osmode oldsnap) ; reset snap mode back to what it was
SNAPMODE effects MATCHPROP? BCAD just normal.
perhaps a reactor, start command MATCHPROP, toggle GRIDMODE to represent SNAPMODE
ACAD not tested
(vl-load-reactors)
(defun c:test-start ( )
; hp 23.06.2020
   (and	matchprop-snap-reactor
	(vlr-added-p matchprop-snap-reactor)
	(vlr-remove matchprop-snap-reactor)
      (setq *matchprop-snapmode*
	     (mapcar 'getvar '(snapmode gridmode))
	     (vlr-command-reactor
	       nil
	       '((:vlr-commandwillstart . matchprop-snap-turn-off)
		 (:vlr-commandEnded . matchprop-snap-restore)
		 (:VLR-commandCancelled . matchprop-snap-restore)
  (grtext -1 "\nMatchprop-snap-reactor activated! ")
(defun matchprop-snap-turn-off (react callback )
  (grtext -1 "\nMatchprop-snap-reactor. ")
 (if (wcmatch (vl-princ-to-string (car callback)) "*MATCHPROP*")
     (princ (strcat "\nSNAPMODE = " (itoa (car (mapcar 'setvar '(snapmode gridmode) '(0 0))))))
(defun matchprop-snap-restore (react callback )
    (if (and (wcmatch (vl-princ-to-string (car callback)) "*MATCHPROP*")
	     *matchprop-snapmode* )
      (princ (strcat "\nSNAPMODE = "(itoa (car (mapcar 'setvar '(snapmode gridmode) *matchprop-snapmode*)))))
(defun c:test-end ()
  (grtext)
  (princ "\nmatchprop-snap-reactor ended!")
Edited by hanhphuc
test-end (and... )
