tremazol Posted June 28, 2020 Posted June 28, 2020 Hey people, I'm in trouble with more than 300 blocks. I need to change the true color of a specific hatches in certain blocks to another true color. Here is a lisp Open that works almost fine, but when it is entered the command "-encc", it opens the menu for the colors from 0 to 256 and not the true colors tab. I'll be really happy if someone could add the true color tab. Thanks in advance, Maxim Quote
tremazol Posted June 28, 2020 Author Posted June 28, 2020 Here is the lisp that almost works Quote (defun c:encc () (pl:block-ent-color) (princ)) ;;;get from Alaspher http://forum.dwg.ru/showthread.php?t=1036 ;;; http://forum.dwg.ru/showpost.php?p=166220&postcount=18 (vl-load-com) (defun pl:block-ent-color (/ adoc blocks color ent lays) (setq adoc (vla-get-activedocument (vlax-get-acad-object)) lays (vla-get-layers adoc) color (acad_colordlg 256) ) (if color (progn (setvar "errno" 0) (vla-startundomark adoc) (while (and (not (vl-catch-all-error-p (setq ent (vl-catch-all-apply (function nentsel) '("\nSelect entity <Exit>:") ) ) ) ) (/= 52 (getvar "errno")) ) (if ent (progn (setq ent (vlax-ename->vla-object (car ent)) lay (vla-item lays (vla-get-layer ent)) ) (if (= (vla-get-lock lay) :vlax-true) (progn (setq layloc (cons lay layloc)) (vla-put-lock lay :vlax-false) ) ) (vl-catch-all-apply (function vla-put-color) (list ent color)) (vla-regen adoc acallviewports) ) (princ "\nNothing selection! Try again.") ) ) (foreach i layloc (vla-put-lock i :vlax-true)) (vla-endundomark adoc) ) ) (princ) ) (defun pl:block-color (/ adoc blocks color ins lays) (setq adoc (vla-get-activedocument (vlax-get-acad-object)) blocks (vla-get-blocks adoc) lays (vla-get-layers adoc) color (acad_colordlg 256) ) (if color (progn (setvar "errno" 0) (vla-startundomark adoc) (while (and (not (vl-catch-all-error-p (setq ins (vl-catch-all-apply (function entsel) '("\nSelect block <Exit>:") ) ) ) ) (/= 52 (getvar "errno")) ) (if ins (progn (setq ins (vlax-ename->vla-object (car ins))) (if (= (vla-get-objectname ins) "AcDbBlockReference") (if (vlax-property-available-p ins 'path) (princ "\nThis is external reference! Try pick other.") (progn (_pl:block-color blocks ins color lays) (vla-regen adoc acallviewports) ) ) (princ "\nThis isn't block! Try pick other.") ) ) (princ "\nNothing selection! Try again.") ) ) (vla-endundomark adoc) ) ) (princ) ) (defun _pl:block-color (blocks ins color lays / lay layfrz layloc) (vlax-for e (vla-item blocks (vla-get-name ins)) (setq lay (vla-item lays (vla-get-layer e))) (if (= (vla-get-freeze lay) :vlax-true) (progn (setq layfrz (cons lay layfrz)) (vla-put-freeze lay :vlax-false)) ) (if (= (vla-get-lock lay) :vlax-true) (progn (setq layloc (cons lay layloc)) (vla-put-lock lay :vlax-false)) ) (vl-catch-all-apply (function vla-put-color) (list e color)) (if (and (= (vla-get-objectname e) "AcDbBlockReference") (not (vlax-property-available-p e 'path)) ) (_pl:block-color blocks e color lays) ) (foreach i layfrz (vla-put-freeze i :vlax-true)) (foreach i layloc (vla-put-lock i :vlax-true)) ) ) (progn (princ "\BLCC - Changes color of the chosen blocks") (princ "\nENCC - Changes color of the chosen objects (may be element of the block)") (princ)) Quote
