dynamic blocks moving proportional
Hi
i need some help with trying to understand what im doing wrong,
what im trying to do is alter the size of the outer block say from 600mm to 1200mm and i want the inner squares to alter size proportionally.
in the drawing attached is 2 blocks  the left block works this was created by some one else , the block on the right is what i have done but i dont know what im missing i think i have copied the lines like the left block but it wont work.
the drawing was done in autocad 2021 saved as 2013
any help would be appreciated many thanks
Drawing.dwg
Check the distance multiplier in the properties for each of the stretch actions, see if you can now spot the difference.
thank you so much spent hours on it yesterday
