Hello Guys
I want to make a lisp file for getting command lisp and produce a file with that command as follows :
(defun c:lspfilemake(/ mmm)
(setq mmm (getstring T "lsp command :"))
(setq filename ( strcat mmm ".lsp")
  (setq file (findfile filename))
   (if (not file)
   	(setq file (open filename "w"))
   );if
  (write-line (strcat  "(defun c:" mmm ".lsp" file))
  (close file)
its mean that
(c:bb)  ---->> bb.lsp
This is my all my mind about it, for any helping would be appreciated
Edited by hosyn
Can you describe what do you want to achieve... command functions can't have spaces so (getstring T) is wrong - it should be just (getstring)... But you want to make lsp file that has inside listed strings you input as command functions - "(defun c:" and ".lsp" is wrong then - it should be "(c:" and ")"... And if you want to invoke routine for several inputs, then (open filename "w") should actually be (open filename "a") - "a"-appending...
Your request does not make much sense why not set up menu etc to pick lisp to run. You could use the multi radio buttons.lsp to have a list of lisp programs to run like Marko can load and run.
