pmadhwal7 Posted July 15, 2020 Posted July 15, 2020 Dear All how to break multiple line at define interval like i want to break attached DWG all polyline at every 50m interval, and if go with manual way it will take many time so Is there any way by which I can select all the Polylines and break them at a time of 50 meters? break line.dwg Quote
BIGAL Posted July 16, 2020 Posted July 16, 2020 Yes ! Using vlax-curve-getpointatdist do it twice 2 pts 50 and 50 + x Do you want a new pline each time so make 2 3 4 5 etc, with common end points. I am sure its already done do a google. Quote
pmadhwal7 Posted July 16, 2020 Author Posted July 16, 2020 4 hours ago, BIGAL said: Yes ! Using vlax-curve-getpointatdist do it twice 2 pts 50 and 50 + x Do you want a new pline each time so make 2 3 4 5 etc, with common end points. I am sure its already done do a google. first thing is i have no idea about vlax-curve-getpointatdist, and no i don't need new pline every time just break those line at 50m interval that's it. Quote
ronjonp Posted July 16, 2020 Posted July 16, 2020 9 hours ago, pmadhwal7 said: first thing is i have no idea about vlax-curve-getpointatdist, .... Do a little reading Here's a simple start: (if (and (setq e (car (entsel "\nPick a polyline: "))) (= 'list (type (setq p (vl-catch-all-apply 'vlax-curve-getpointatdist (list e 50.))))) ) (vl-cmdf "_.break" e p p) ) Quote
devitg Posted July 18, 2020 Posted July 18, 2020 On 7/16/2020 at 1:56 AM, pmadhwal7 said: first thing is i have no idea about vlax-curve-getpointatdist, and no i don't need new pline every time just break those line at 50m interval that's it. When you break a PLINE , or line , or whatever line like enty , you get 2 new one . and so all line long Quote
devitg Posted July 18, 2020 Posted July 18, 2020 give it a try added to Ronjonp start (defun C:brk () (if (and (setq e (car (entsel "\nPick a polyline: "))) (setq e-LENGTH (vla-get-Length (vlax-ename->vla-object e))) (setq div (fix (/ e-LENGTH 50))) (= 'list (type (setq p (vl-catch-all-apply 'vlax-curve-getpointatdist (list e 50.))))) ) (vl-cmdf "_.break" e p p) ) (repeat (1- div) (setq e (entlast)) (= 'list (type (setq p (vl-catch-all-apply 'vlax-curve-getpointatdist (list e 50.))))) (vl-cmdf "_.break" e p p) ) ) Quote
devitg Posted July 18, 2020 Posted July 18, 2020 To break all polys (DEFUN C:BRK (/ ALL-POLY-LIST ALL-POLY-SS DIV E E-LENGTH P) (SETQ ALL-POLY-SS (SSGET "X" '((0 . "LWPOLYLINE")))) (SETQ ALL-POLY-LIST (VL-REMOVE-IF-NOT '(LAMBDA (X) (= (TYPE X) 'ENAME)) (MAPCAR 'CADR (SSNAMEX ALL-POLY-SS)))) ;;; (setq poly (car all-poly-list)) (FOREACH POLY ALL-POLY-LIST (IF (AND (SETQ E POLY) (SETQ E-LENGTH (VLA-GET-LENGTH (VLAX-ENAME->VLA-OBJECT E))) (SETQ DIV (FIX (/ E-LENGTH 50))) (= 'LIST (TYPE (SETQ P (VL-CATCH-ALL-APPLY 'VLAX-CURVE-GETPOINTATDIST (LIST E 50.))))) ) ; end And (VL-CMDF "_.break" E P P) ) ; end if (REPEAT (1- DIV) (SETQ E (ENTLAST)) (= 'LIST (TYPE (SETQ P (VL-CATCH-ALL-APPLY 'VLAX-CURVE-GETPOINTATDIST (LIST E 50.))))) (VL-CMDF "_.break" E P P) ) ) ;end foreach ) all breaked line.dwg Quote
BIGAL Posted July 18, 2020 Posted July 18, 2020 (edited) Why not (FOREACH POLY ALL-POLY-LIST (repeat (setq x (sslength ALL-POLY-SS)) (setq E (ssname ss (setq x (- x 1)))) Edited July 18, 2020 by BIGAL Quote
Jonathan Handojo Posted July 19, 2020 Posted July 19, 2020 Guys... Harsh lesson I learned the hard way, when using (command) or (vl-cmdf) that involves getting a point from user, if your snaps isn't off, you'll get unexpected results. Make sure snaps is off before executing commands. Quote
