Mike001 Posted July 15, 2020 Posted July 15, 2020 When you use the FIND command to find text and a result is found, autocad zooms in on the result. Is it possible to change/edit this zoom factor? Quote
rkmcswain Posted July 15, 2020 Posted July 15, 2020 Not that I am aware of. See also: https://forums.autodesk.com/t5/autocad-forum/find-dialog-box-position-and-zoom-level/td-p/7344959 https://forums.autodesk.com/t5/autocad-forum/find-and-replace-zoom-factor/td-p/2346132 https://forums.autodesk.com/t5/autocad-forum/zoom-in-find-command/td-p/2170046 Quote
Dana W Posted July 16, 2020 Posted July 16, 2020 (edited) Never mind. I misread your post. I also think there is not a way to change the zoom factor. Edited July 16, 2020 by Dana W Quote
