Three question (Multiple entlast, preview and i dont know what it's call)
Hello all. I hope everyone is fine.
1. Is it possible to create multiple entlast?
2. How do i make a "preview" (?) of lines, pline etc before i pick a point? Like copy, there's a secondary object right before i pick a point.
3. Let say i made a circle, and when i pressed '+' it will increse the diameter OR if i press '-' it will decrease. Maybe something that can be use beside circle.
If you can, please comment using autolisp not in VL ( im new and still learning). Thank you for your time.
Edited by Sheep
  1. I don't understand this one.
  2. In a simple way, it's not possible. In more advanced ways by using LM:GrSnap, it links to the third question you asked.
  3. This utilises a function in AutoLISP known as grread. It basically reads any input AutoCAD receives. Combining grread with the while loop, you can enhance this feature. I think it might be too hard for you to understand this, but you can have a look at some examples.
Below is my example of a circle that will move alongside your circle, while pressing + and - will modify its radius.
(defun c:tc ( / cir gr grp grv inc rad)
    (setq cir (entmakex '((0 . "CIRCLE") (10 0.0 0.0 0.0) (40 . 10)))
	  rad 10
	  inc 1	; I'll use this as example to indicate the amount of radius it will increase and decrease with every press
    (while
	    (setq gr (grread t 15 0)	; returns any input received by AutoCAD (at that instant moment [I think?])
		  grp (cadr gr)		; the value associated with the input (can vary)
		  grv (car gr)		; the type of input AutoCAD received
	    (cond
		((= grv 5)	; a value of 5 indicates mouse movement (and 'grp' would then be the coordinates of the cursor in UCS)
		 (entmod	; so everytime your mouse moves, you modify its center point to the mouse cursor.
		     (subst
			 (cons 10 grp)
			 (assoc 10 (entget cir))
			 (entget cir)
		((= grv 2)	; a value of 2 indicates keyboard input (and 'grp' will be an integer representing the code returned by (ascii)... (ascii "+") --> 43
		 (cond
		     ((= grp 45)	; <-- This is if the "-" key is pressed
		      (if
			  (or	; if the user presses "-" when the radius is 1, that's invalid, so include this check
			      (minusp (- rad inc))
			      (zerop (- rad inc))
			  (princ "\nRadius cannot be set smaller")
			  (entmod	; otherwise, modify the radius to decrease by 1
			      (subst
				  (cons 40 (setq rad (- rad inc)))
				  (assoc 40 (entget cir))
				  (entget cir)
		     ((member grp '(43 61))	; This is if the "+" key is pressed... In your keyboard, you may see it as "+", but what you're really pressing is "=", thus 61.
		      (entmod	; modify the radius to increase by 1
			  (subst
			      (cons 40 (setq rad (+ rad inc)))
			      (entget cir)
		((= grv 3)	; a value of 3 indicates a mouse click. You'd want to end the command when this happens
		 nil		; so include 'nil' to escape the while loop
		(t)		; Anything else, return T to stay within the loop and repeat.
If you can use it, you can utilise it to do all sorts of cool things. Some examples are Limited Length Polyline, Align Text to Curve, TracePoly
Plus, what's wrong with vl? You can't do many things that vl offers... like extracting block attributes, getting dynamic block properties...
Edited by Jonathan Handojo
  • Thanks 1
58 minutes ago, Jonathan Handojo said:
  1.
	  rad 10
    (while
	    (cond
		     (subst
			 (cons 10 grp)
			 (entget cir)
		 (cond
		      (if
			      (zerop (- rad inc))
			      (subst
				  (entget cir)
			  (subst
			      (entget cir)
Nothing is wrong with VL. Im new to autolisp even at the most basic level. I need to understand autolisp before moving to VL.
For the first question, is it possible to make multiple entlast so i dont have to immediately call it.  For example i made a circle (entlast) but later on i would like to merge the circle with a new entlast after a different set of calculation is done.
I assume LM:Grsnap referring to Lee Mac right? I'll check that later today. Thank you for your response.
Yes, it refers to Lee Mac. With grread, you can't actually snap your cursor to any of the OSMODEs. Which is why Lee created that function to enhance grread, and I create GrPolar in that TracePoly link.
I mean you can always do:
(defun c:test ( / lst rtn)
    (setq lst (entlast) rtn (list lst))
    ;; do your thing here
    (while (setq lst (entnext lst))
	(setq rtn (cons lst rtn))
If you want a selection set can do in a couple of ways ssadd the entlast or make a list using cons of the entity names.
(ssadd [<ENAME>][<SS>])
Adds entities to selections sets.
(setq ss (cons (entlast) ss)
Dynamic radius maybe +5 -10 +23.45 look at the two parts - + and the xxxx, + - on own uses default inc. Use getstring input.
Another using grips 'cal  (rad + 10)
  • Thanks 1
