yes, if they should need some odd door tag that would be set on both sides.
  • Replies 33
  • Lee Mac
    17
  • JDRBWA
    13
  • Tankman
    3
  • CAB
    1
Posted Images
Ok try this - although the LISP is getting messy now with so many alterations :(
There is probably a better way to write it, but it would mean re-writing most of the LISP, so try this for now :)
(defun c:tagger     (/ *error* vLst oVars ans pTxt    sNum sNumt sTxt    cnt iPt    drTag bubTag drTagLst bubTagLst    lAns 1pt 2pt
         lAng chrLst sChr)
 (vl-load-com)
 (defun *error*  (msg)
   (if    oVars
     (mapcar 'setvar vLst oVars))
   (if    (eq "" msg)
     (princ "\n<< Function Complete >>")
     (princ (strcat "Error: " (strcase msg))))
   (princ))
 (setq    vLst  (list "OSMODE" "CLAYER" "ATTREQ" "BLIPMODE" "CMDECHO")
   oVars (mapcar 'getvar vLst))
 (mapcar 'setvar vLst (list 0 "0" 0 0 0))
 (mapcar 'makelay '("A-DOOR-IDEN" "S-GRID-IDEN" "S-GRID") '("5" "4" "2"))
 (if (and (tblsearch "BLOCK" "Tagdoor1") (tblsearch "BLOCK" "Grdbub01"))
     (if (not TG:oans)
   (setq TG:oans "Door"))
     (if (not TG:olans)
   (setq TG:olans "Yes"))
     (initget "Door Bubble")
     (setq ans (getkword (strcat "\nSpecify Tag Type [Door/Bubble] <" TG:oans ">: ")))
     (if (not ans)
   (setq ans TG:oans)
   (setq TG:oans ans))
     (if (and (setq pTxt (getstring t "\nSpecify Prefix Text <Enter for no Prefix>:  ")
            sNum (getstring "\nSpecify Incremental String: ")
            sTxt (getstring t "\nSpecify Suffix Text <Enter for no Suffix>:  ")))
     (if (txt2num sNum)
       (setq sNum (txt2num sNum))
       (setq sNumt (vl-string->list sNum)))
     (setq cnt 0)
     (cond    ((= ans "Bubble")
        (initget "Yes No")
        (setq lAns (getkword (strcat "\nGrid-Line? [Yes/No] <" TG:olans ">: ")))
        (if (not lAns)
          (setq lAns TG:olans)
          (setq TG:olans lAns))
        (cond ((= lAns "No")
           (if sNumt
               (setq sChr (last sNumt))
               (while (and    (setq iPt (getpoint "\nSelect Point for Symbol > "))
                   (< (+ sChr cnt) 90))
                 (setvar "clayer" "S-GRID-IDEN")
                 (command "-insert" "Grdbub01" iPt "" "" "")
                 (setq bubTag (entnext (entlast)))
                 (while (/= "SEQEND" (cdadr (setq bubTagLst (entget bubTag))))
               (if (= "GRIDNUM" (cdr (assoc 2 bubTagLst)))
                 (entmod (subst (cons 1 (strcat pTxt (chr (+ sChr cnt)) sTxt))
                        (assoc 1 bubTagLst)
                        bubTagLst)))
               (setq bubTag (entnext bubTag)))
                 (command "_regenall")
                 (setq cnt (1+ cnt))))
             (while (setq iPt (getpoint "\nSelect Point for Symbol > "))
               (entmod    (subst (cons 1 (strcat pTxt (rtos (+ sNum cnt) 2 0) sTxt))
                          (assoc 1 bubTagLst)
                          bubTagLst)))
               (setq cnt (1+ cnt)))))
              ((= lAns "Yes")
           (if sNumt
               (while (and    (setq 1pt (getpoint "\nSpecify Grid-Line First Point > "))
                   (setq 2pt (getpoint 1pt "\nSpecify Second Grid-Line Point > "))
                 (setvar "clayer" "S-GRID")
                 (command "_line" 1pt 2pt "")
                 (setq grLin (entlast)
                   lAng  (angle 1pt 2pt)
                   iPt      (polar 2pt lAng 0.5))
                        (assoc 1 bubTagLst)
                        bubTagLst)))
                     (setq 2pt (getpoint 1pt "\nSpecify Second Grid-Line Point > ")))
                          (assoc 1 bubTagLst)
                          bubTagLst)))
               (setq cnt (1+ cnt)))))))
       ((= ans "Door")
        (setq chrLst (vl-string->list sTxt))
        (if chrLst
          (setq sChr (last chrLst))
          (setq sChr 65))
                (< (+ sChr cnt) 91))
          (setvar "clayer" "A-DOOR-IDEN")
          (command "-insert" "Tagdoor1" iPt "" "" "")
          (setq drTag (entnext (entlast)))
          (while (/= "SEQEND" (cdadr (setq drTagLst (entget drTag))))
            (if (= "DR1NUM" (cdr (assoc 2 drTagLst)))
              (entmod (subst (cons 1 (strcat pTxt (rtos sNum 2 0) (chr (+ sChr cnt))))
                     (assoc 1 drTagLst)
                     drTagLst)))
            (setq drTag (entnext drTag)))
          (setq cnt (1+ cnt))))))))
   (princ "\n<!> One or More Blocks not Found <!>"))
 (*error* "")
 (princ))
(defun makelay    (x y)
 (if (not (tblsearch "LAYER" x))
   (command "-layer" "M" x "C" y x "")))
(defun txt2num    (txt / num)
 (or (setq num (distof txt 5))
     (setq num (distof txt 2))
     (setq num (distof txt 1))
     (setq num (distof txt 4))
     (setq num (distof txt 3))
 (if (numberp num)
   num)
Yeah, i think we have a couple pots in the fire hehe.
The last lisp you gave me didnt have the locate file instead it was looking for teh block in teh dwg already. I tried to change out the line and I broke it.
So the Alpha works only on the first AA I input it just gives me an A, B, C. sequence.
Ah, ok, just to test it I put a single letter - so, you want the increments like:
AA, BB, CC and not AA AB AC AD...
Also, about the other LISP - did you modify the filepaths as necessary?
OK, try this:
         lAng chrLst sChr sChr1 sChr2)
 (vl-load-com)
   (if    oVars
   (if    (eq "" msg)
   (princ))
     (if (not TG:oans)
     (if (not TG:olans)
     (if (not ans)
   (setq ans TG:oans)
   (setq TG:oans ans))
     (if (txt2num sNum)
     (setq cnt 0)
     (cond
       ((= ans "Bubble")
        (initget "Yes No")
        (if (not lAns)
        (cond
          ((= lAns "No")
       (if (and sNumt (>= (length sNumt) 2))
           (setq sChr1    (last sNumt)
             sChr2    (nth (- (length sNumt) 2) sNumt))
               (< (+ sChr1 cnt) 90)
               (< (+ sChr2 cnt) 90))
             (entmod (subst (cons 1 (strcat pTxt (chr (+ sChr2 cnt)) (chr (+ sChr1 cnt)) sTxt))
                    (assoc 1 bubTagLst)
                    bubTagLst)))
                      (assoc 1 bubTagLst)
                      bubTagLst)))
          ((= lAns "Yes")
                    (assoc 1 bubTagLst)
                    bubTagLst)))
                      (assoc 1 bubTagLst)
                      bubTagLst)))
       ((= ans "Door")
        (if chrLst
          (setq sChr 65))
                 (assoc 1 drTagLst)
                 drTagLst)))
 (*error* "")
 (princ))
 (if (numberp num)
   num)
If you enter AA - will increment AA BB CC etc etc
If you enter AB - will increment BC CD DE etc etc
I have removed the possibility of a single letter increment though.
This worked great, I had to adjust it a little so that it brought in a linetype for s-grid.
Can we make this one look at a file location instead of the block?
Also in the lisp we use now we have a Dimscale preset
(setq DIM (GETVAR "dimscale"))
; (setq SZ1 (* 0.5625 DIM))
; (setq DS1 (* 0.28125 DIM))
(setq SZ1 (* 0.5 DIM)) ; Modified 09 Aug 1999 to New Office Standards
(setq DS1 (* 0.25 DIM)) ; Modified 09 Aug 1999 to New Office Standards
So maybe we should simplify this some. The most current lisp. Lets just say it is for grid bubbles. not doors because they are the one that would not need a AA increment but a A increment.
SZ1...DS1??? What are these?
At the minute, the Doors increment by a single letter (in the suffix)
and the Bubbles can increment by either two letters or a number.
  • 1 year later...
Interesting post! Replies are excellent.
Lee Mac speaks with a lisp as always!
That is quite an old LISP! I could probably write it much better... :geek:
I'm sure you can! Have never wrote a lisp but do use them.
Great time savers and your work always has a bit of uniformity.
One lisp I have loaded each time I open AutoCAD is Callout.
The lisp has a need to be updated/upgraded.
One problem would be color selection.
The lisp always makes a color, magenta. Might be nice to select a color.
Second up, scale, sometimes the balloon is tiny, sometimes BIG.
Last, arrow is always filled. I usually use a blank arrow.
Check this lisp out if you're inclined, bored, or need something to do.
I'm sure your efforts would be rewarded in Heaven at least! :roll:
Callout.lsp
Thanks Mr. Lisp. I tried Luis' lisp, wow!
I think too much more than I might like or would use.
My "stuff" is simple plan and elevation views; tanks, pipe, valves.
I usually just use B3B and keep it simple. If needed, I edit the text in the bubble; i.e.: 1 edit to A. I usually just live with numbers for the nozzle schedule which we generate manually as we go.
The fitting is showing two CALLOUT bubbles, one would be the norm.
A or B. Simple stuff as shown on the 4" flange.
Yeah, Luis' LISP is very advanced - using reactors to update the position of the callout when moved etc. But worth a look. :)
