HI
Please help me with the following LISP routine for which I am including a copy
On my AUTOCAD 2013 this routine that I wrote works perfectly
BUT
Copied to my AUTOCAD 2018 it does not execute the second part as described under item (2)
Routine description
The routine is for
(1) drawing an arrow and leader lines (LEFT TO RIGHT) (until terminated) and then allows the user to add some annotation with
the text being LEFT JUSTIFIED
(2) drawing an arrow and leader lines (RIGHT TO LEFT) (until terminated) and then allows the user to add some annotation with
the text being RIGHT JUSTIFIED
Instead it does, the arrow and leader lines correct until it gets to the annotation, then does LEFT JUSTIFIED text instead of RIGHT JUSTIFIED text
It also position the text in the wrong position with regard to the end of the leader line
COPY OF LISP N-002.lsp
N-002.LSP
Thanks in advance
nieko
It probably fails because there's no longer a quick snap that was handy a quarter century ago.
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/autolisp-osnap-function-2016/m-p/6209480#M339621
Loaded your routine, set a value to "useri1", added the "txt-p025" layer, still wouldn't work without DTR function which is usually a Degrees To Radians function.
Not sure why you would use "useri*" variables since they're stored in the drawing same as your x, y, z, q, and u global variables which would allow real numbers like a text height of 2.6. x is the only one even used in the lisp.
Out of Curiousity: why would you not switch to the MLEADER command? IT is ten times more versatile than your little routine from 1990. Do you have to do it that way for some kind of export to another program?
