Enhanced Attribute text appears different size from one computer to another
hello, my text (enhanced attribute editor) appears one size in one computer and another size in another.
i have them both set as the same scale,
same font is loaded on both computers.
the box to change from annotative to non is grayed out. not sure what to do can someone help?
If the style is Standard, the parameters will be whatever was last imported as Standard. If that's the case, try using a different style with the same parameters.
Another strategy is to sync the attributes. That will bring the parameters in line with the current definition and get rid of any overrides.
Do you have the same issue with regular text, or is it just attributes?
I switched the font style and the same thing happens, it only affects my attributes
Can you post some images and a drawing file?
I've seen that with attributes with elevations other than zero.
If the cursor locks on to the attribute's grip does a Z value other than 0.0 show in the Coordinate Display?
