Mschiliro Posted August 10, 2020 Share Posted August 10, 2020 hello, my text (enhanced attribute editor) appears one size in one computer and another size in another. i have them both set as the same scale, same font is loaded on both computers. the box to change from annotative to non is grayed out. not sure what to do can someone help? Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted August 11, 2020 Share Posted August 11, 2020 If the style is Standard, the parameters will be whatever was last imported as Standard. If that's the case, try using a different style with the same parameters. Another strategy is to sync the attributes. That will bring the parameters in line with the current definition and get rid of any overrides. Do you have the same issue with regular text, or is it just attributes? Quote Link to comment Share on other sites More sharing options...
Mschiliro Posted August 12, 2020 Author Share Posted August 12, 2020 23 hours ago, CyberAngel said: If the style is Standard, the parameters will be whatever was last imported as Standard. If that's the case, try using a different style with the same parameters. Another strategy is to sync the attributes. That will bring the parameters in line with the current definition and get rid of any overrides. Do you have the same issue with regular text, or is it just attributes? I switched the font style and the same thing happens, it only affects my attributes Quote Link to comment Share on other sites More sharing options...
SLW210 Posted August 13, 2020 Share Posted August 13, 2020 Can you post some images and a drawing file? Quote Link to comment Share on other sites More sharing options...
tombu Posted August 13, 2020 Share Posted August 13, 2020 I've seen that with attributes with elevations other than zero. If the cursor locks on to the attribute's grip does a Z value other than 0.0 show in the Coordinate Display? Quote Link to comment Share on other sites More sharing options...
