I am having a problem moving the origin in a drawing to ordinate dimension it. I do  have
an outline that I made  for the procedure, however I cannot get it to work.  Will someone here please
read my instructional outline and see where I went wrong with the sequence.  I have
enclosed a doc file for your view.
Thank you,
Ezra
Ordinate Dimensioning .doc
A possible better way is UCS OB pick left hand corner, this will allow for an angled object not just a X & Y axis.
It would help to give guidance where you are going wrong if you could post an actual example drawing, and say what results you were getting.
There are many instances of not getting what you want, for example what Object Snaps are you using??
Are you still using Autocad 2000?
Is the new UCS rotated???
Why do you not want to see the UCS icon?
