Alexandre PETIT Posted September 1, 2020 Posted September 1, 2020 (edited) Quote Translation Hi all I'm having a problem with Autocad 2019. I want to copy/paste a drawing from a plan A to a plan B. Unfortunately, the drawing arrives in B with a lag of certain block elements. I do not want to have to reposition them because it would be long and difficult. However, I do not understand the reason for this discrepancy and cannot solve this problem. Has anyone ever met this scenario? Any idea how to solve this problem? Thank you in advance for your help. Kind regards Bonjour à tous, Je rencontre un souci sur Autocad 2019. Je souhaite copier/coller un dessin d'un plan A vers un plan B. Malheureusement, le dessin arrive dans B avec un décalage de certains éléments blocs. Je ne veux pas avoir à les repositionner car cela serait long et difficile. Je ne comprends cependant pas la raison de ce décalage et n'arrive pas à résoudre ce problème. Quelqu'un a-t-il déjà rencontré ce cas de figure ? Une idée pour résoudre ce problème ? Je vous remercie par avance pour votre aide. Cordialement, Edited September 2, 2020 by SLW210 Translate Quote
CyberAngel Posted September 4, 2020 Posted September 4, 2020 What type(s) of elements are causing the problem? If you override the properties of attributes, those overrides don't carry over when you copy or insert the block somewhere else. As always, the more you tell us, the better we can help you. Give us a screen shot or a copy of your block, if you can. Quote
steven-g Posted September 4, 2020 Posted September 4, 2020 Does Plan B already contain blocks that have the same name but uses a different block definition? If you try to transfer blocks betwee drawings the block definition that already exists in Plan B will be used and ignore any new content that was in updated blocks coming in from Plan A. Or Does Plan B have certain layers turned off? Quote
