Have You Tried: Selection Cycling in AutoCAD
The AutoCAD Blog
For the new Have You Tried, we want to talk about a selection technique called selection cycling in AutoCAD. It’s used when drawing objects are stacked on top of each other or overlapping, making it difficult to select the object you want to modify.
Discover a couple of ways to use selection cycling and some of the display settings for the Selection list box. Also learn how to remove duplicate objects based on an object’s color, layer, linetype, linetype scale, and several other object properties using the OVERKILL command.
Learn more about how to select stacked objects with step-by-step examples in the Have You Tried: Selection Cycling topic.
AutoCAD selection cycling
Keep the Feedback Coming
Thanks for all the great feedback submitted so far. Because of the great feedback, we have been able to improve the topics in the AutoCAD Online Help system.
The best way to submit feedback is by using the “Was this helpful?” section located at the bottom of every Help topic. Let us know what you like or don’t like about a topic or provide suggestions for other subjects that you’d like to see covered in greater detail. The more specific your comments, the better.
The post Have You Tried: Selection Cycling in AutoCAD appeared first on AutoCAD Blog.
hxNEYhEAdqU
View the full article
