YoMo Posted September 2, 2020 Posted September 2, 2020 Hi there, I'm creating a titleblock from scratch. I've tried various methods of inserting a company logo i.e. as a raster image, a OLE file, block etc. But each time I close the drawing and reopen the logo/image disappear? I tried using a dwg file, jpeg etc. Nothing works. When I try to create a Wblock from the image it disappear as well. Sooo frustrating. Please help! Quote
f700es Posted September 2, 2020 Posted September 2, 2020 I'd either get or make a vector image of the logo and then save it as a .wmf file and then insert to use in my titleblock. wmfin command will do it for you Quote
CyberAngel Posted September 2, 2020 Posted September 2, 2020 When I have this problem, it's usually because the image file is not in the same folder as the drawing. For some reason, closing the file breaks the path to the image. Quote
RobDraw Posted September 2, 2020 Posted September 2, 2020 2 hours ago, CyberAngel said: When I have this problem, it's usually because the image file is not in the same folder as the drawing. For some reason, closing the file breaks the path to the image. That is not normal behavior. The path should be saved regardless. Now if the pathing were relative and a save as to a different location took place, it would be expected but I'm pretty sure AutoCAD throws an error in this case and can fix the relative pathing for you. Quote
