Hi All,
Is there any lisp code to identify the smallest line and label its length from the selected lines.
if you have come across any such code please let me know
Thanks in advance.
5 hours ago, symoin said:
Hi All,
Thanks in advance.
Are you refering to just "LINE" lines or does this include arcs, circles, ellipses, lwpolylines, splines etc?
Like dlanorh just select objects and get the length and save object entity name in a varible if less than.
*lines & arc  vla-get-length
Circle vla-get-circumference
Mostly it will be lines and some times it will have lwpolylines along with the lines.
Hi devitg no need for acdoc code
  (SETQ LENGTH+HANDLE-LIST ())
  (repeat (setq x (sslength lines-ss))
  (setq  LINE-OBJ  (vlax-ename->vla-object (ssname LINES-SS (setq x (- x 1)))))
