Hi everyone
i need yours help again
i'm trying copy field from one block to another block
the problem is that in the end i cant see the resault and it show me ####
only if i go inside the field and press ok it show me the resault
any idea how to fix it
MOLS.lsp
Call the command REGEN after copying if your codes running correctly without any issue.
i try it already
its not refresh it
maybe because its field inside field
The main issue is that you are selecting the block reference with (car (entsel)). A block reference does not have a TextString property.
(defun C:MOLS (/ att base blk doc obj sca space str)
  (vl-load-com)
  (setq doc (vla-get-activedocument (vlax-get-acad-object)))
  (setq space
    (if (= 1 (getvar 'cvport))
      (vla-get-paperspace doc)
      (vla-get-modelspace doc)
  (setq obj (car (nentsel "\nSelect an attribute: ")))
  (setq base (getpoint "\nSelect base point: "))
  (setq str (strcat "%<\\AcObjProp.16.2 Object(%<\\_ObjId " (itoa(vla-get-ObjectID (vlax-ename->vla-object obj))) ">%).TextString \\f \"%tc1\">%"))
  (setq sca (getvar 'dimscale))
  (setq blk
    (vla-insertblock
      space
      (vlax-3d-point base)
      "SH1"
      sca
      sca
      sca
      0
  (setq att (car (vlax-invoke blk 'getattributes)))
  (vla-put-textstring att str)
ROY THX
ITS WORK :)
THE ISSUE IS THAT WORKING ONLY IF I DIRECTLY POINT ON THE ATTRIBUTE TEXT AND NOT THE BLOCK
THERE IS ANYWAY TO CHANGE IT?
OR ATLEAST IT WONT LET ME CHOOSE THE BLOCK
(defun C:MOLS (/ attNew attSel base doc enmSel objNew objSel sca space str)
  (vl-load-com)
  (vla-endundomark doc)
  (vla-startundomark doc)
  (if
    (and
      (setq enmSel (car (entsel)))
      (setq objSel (vlax-ename->vla-object enmSel))
      (vlax-method-applicable-p objSel 'getattributes)
      (setq attSel (car (vlax-invoke objSel 'getattributes)))
      (setq base (getpoint "\nSelect Base Point: "))
      (setq space
      (setq str
        (strcat
          (itoa (vla-get-objectid attSel))
      (setq objNew
        (vla-insertblock
          space
          "SH1"
          sca
          sca
          sca
          0
      (setq attNew (car (vlax-invoke objNew 'getattributes)))
      (vla-put-textstring attNew str)
  (vl-load-com)
  (if
    (and
      (setq space
      (setq str
        (strcat
      (setq objNew
        (vla-insertblock
          space
          "SH1"
          sca
          sca
          sca
          0
HI ROY
THIS ONE NOT WORKING
HE CANT FIND THE FIELD
First of all: please switch off CapsLock when writing forum posts. All caps texts are annoying.
Are you testing the new code on the same machine and AutoCAD version as the previous code?
Sorry for the CapsLock
i change the Code because it didnt work and use the nentsel that u advise
there is the code that i use
(defun C:MOLS (/ obj )
		(vl-load-com)
		(setq AcDoc (vla-get-ActiveDocument (vlax-get-acad-object)))
		(setq Space
			(if (= 1 (getvar "CVPORT"))
				(vla-get-PaperSpace AcDoc)
				(vla-get-ModelSpace AcDoc)
	;(setq obj (car (entsel "\nSelect an Attributed Block: ")))
	(setq BASE (getpoint "\nSelect Base Point: "))
	(setq YY 	(strcat "%<\\AcObjProp.16.2 Object(%<\\_ObjId " (itoa(vla-get-ObjectID (vlax-ename->vla-object obj))) ">%).TextString \\f \"%tc1\">%"))
	(command "_.Insert" "SH1" base (getvar "DIMSCALE") "" "" YY "")
(prin1)
) ;END
Just saying 'it does not work' is not going to get us anywhere. I have made an assumption regarding the source block that is selected. That assumption may be wrong. Please post a file with a block that the new code does not handle properly.
Hi roy
I add the DWG with the block
next to each block i write text
the main goal is to read the middle block (that contain data from the below block) and make a new block (the top one)
thx again for the help
new block.dwg
The new code seems to work OK with your example DWG. The source block you select has a single attribute, and this matches my assumption. I can't think of a reason why the first version of my code works and the second version fails, other than that you are testing with different AutoCAD versions (32/64 bit).
roi thx again and sorry for the bad english
i success to fix it
i used
		BASE_BB (entsel "\nSelect Base Point: ")
		obj (entnext (car BASE_BB))
