Default Viewport settings
I am using ADT2006, the firm I work in uses Project Navigator for all of their projects.
My question is: When dragging a view file into a sheet file the viewport created is set to the lock position by default. Is there any way that I can get the viewport to be created in the unlocked position by default?
Thanks in advance.
Thanks in advance.
I do not believe that there is a way to get this to stay unlocked. It might be a good question in the general forums as well, since the sheet set manager is essentially our sheet set items in ACA
