Kalsefar Posted October 8, 2020 Posted October 8, 2020 (edited) Hello Everyone, I'm looking for a code that's can help me to export coordinates for the point of intersection . please look to the attached file be more clear Edited October 8, 2020 by Kalsefar Quote
hosneyalaa Posted October 8, 2020 Posted October 8, 2020 (defun c:test (/ ) (if (setq ss (ssget '((0 . "point")))) (repeat (setq i (sslength ss)) (setq e (entget (ssname ss (setq i (1- i))))) (princ (cdr (assoc 10 e))) ) ) ) Quote
BIGAL Posted October 8, 2020 Posted October 8, 2020 (edited) 1 If you set osmode to 32 it will find the intersection point. 2 If its a block then generally the intersection is the insertion point. 3 Like hosneyalaa if a "Point". You need to clarify which it is. There is so many export points to csv file examples out there just google. Edited October 8, 2020 by BIGAL Quote
Lee Mac Posted October 9, 2020 Posted October 9, 2020 Assuming the image shows two separate lines, obtain the coordinates the line end points from DXF groups 10 & 11 and then use the inters function to calculate the point of intersection. Quote
BIGAL Posted October 9, 2020 Posted October 9, 2020 Like lee if its a symetrical 2 lines around mid point pick 1 line. (setq lin (car (entsel "\nPick line"))) (setq pt (mapcar '/ (mapcar '+ (vlax-curve-getStartPoint lin) (vlax-curve-getEndPoint lin)) '(2 2 2))) Quote
