svorgodne Posted October 13, 2020 Posted October 13, 2020 Hi everyone, I use very often the command combination "zoom" "object", either via a lisp program or normal input. My question is, how to manage the percentage the object appear on the screen. Is there a system variable that can control that? I would like to have the objet selected as big as it is occupaying the whole screen when I use this command combination. Thanks in advance Quote
guran Posted October 13, 2020 Posted October 13, 2020 Have this old lisp. Do not remember where I got it . (Defun C:ZO () ;; Turns UCS and zooms to object (command ".ucs" "ob" pause ".plan" "c" ".zoom" "w" '(-10 -10) '(10 10)) (princ) ) Quote
tombu Posted October 13, 2020 Posted October 13, 2020 If you'd rather not change your UCS gile at TheSwamp wrote a ZoomObject lisp that works with TWisted views us in Civil/Survey work use on every project: https://www.theswamp.org/index.php?topic=20534.msg250028#msg250028 Quote
BIGAL Posted October 13, 2020 Posted October 13, 2020 Maybe a simple way just using the scale variable you can have more than one scale defun. (defun c:z20 ()(command "zoom" "c" (getpoint "\pick point") 20)) Quote
