3DArc: Lisp Error : error: bad argument type: 2D/3D point
I made a LISP to generate 3D arc from the CSV file.
(defun c:rects ()
(setq f (open "D:/3DY/FromAutoCAD/Circle.csv" "r"))
(setq dataline (read-line f))
(setq x 1)
(setq a 0)
(setq b 0)
(setq c 0)
(while (/= dataline "EOF")
(vl-string-left-trim " " dataline)
(vl-string-right-trim " " dataline)
(if ( = (rem x 3) 0)
        (setq c dataline)
        (princ a)
        (princ b)
        (princ c)
        (command "_ucs" "_w")
        (command "_ucs" "_3p" a b c)
        (command "_arc" (trans a 0 1)(trans b 0 1)(trans c 0 1))
(if ( = (rem x 3) 1)
    (setq a dataline)
(if ( = (rem x 3) 2)
    (setq b dataline)
(setq x (+ 1 x))
(close f)
Sample of CSV file
X,Y,Z
221931.63200000036,401253.0739999904,18.268999970437235
221934.92300012588,401257.3900002136,18.269000183106428
221939.25799999948,401259.3889999542,18.23599997806663
221919.44000004293,401265.3299999994,18.11499998617286
221924.67399997663,401259.0890000062,18.223000026227183
221924.88300002765,401255.6249999981,18.25399998474235
But while running it, I am facing an error.
Command: RECTS
221931.63200000036,401253.0739999904,18.268999970437235221934.92300012588,401257.3900002136,18.269000183106428221939.25799999948,401259.3889999542,18.23599997806663_ucs
Current ucs name:  *WORLD*
Specify origin of UCS or [Face/NAmed/OBject/Previous/View/World/X/Y/Z/ZAxis] <World>: _w
Command: _ucs
Specify origin of UCS or [Face/NAmed/OBject/Previous/View/World/X/Y/Z/ZAxis] <World>: _3p
Specify new origin point <0,0,0>: 221931.63200000036,401253.0739999904,18.268999970437235
Specify point on positive portion of X-axis <221932.6320,401253.0740,18.2690>: 221934.92300012588,401257.3900002136,18.269000183106428
Specify point on positive-Y portion of the UCS XY plane <221930.8368,401253.6803,18.2690>: 221939.25799999948,401259.3889999542,18.23599997806663
Command: _arc
Specify start point of arc or [Center]: ; error: bad argument type: 2D/3D point: "221931.63200000036,401253.0739999904,18.268999970437235"
I have check my ARC generation code part with another lisp code, which is working as expected, no error.
(defun c:3Darc (/ p1 p2 p3)
 (setq p1 (getpoint "Arc point #1: "))
 (setq p2 (getpoint "Arc point #2: "))
 (setq p3 (getpoint "Arc point #3: "))
 (command "_ucs" "_3p" p1 p2 p3)
 (command "_arc" (trans p1 0 1)(trans p2 0 1)(trans p3 0 1))
Please help to solve this.
Thanks,
Yash
Hello i modify your code and thik this may work for you.
If i understand correct every 3 point from your list is different arc.
(defun T:spaceremover (lst / ttr ttr2)
	(setq ttr (subst 32 44 (subst 32 9 (vl-string->list lst))))
		(repeat (length ttr)
			(if (and (= (car ttr) 32) (= (cadr ttr) 32)) (princ) (setq ttr2 (cons (car ttr) ttr2)))
			(setq ttr (cdr ttr))
	(vl-string-trim " " (vl-list->string (reverse ttr2)))
(defun LM:group<n ( l n / a b m )
    (while l
        (setq m n)
        (while (and l (< 0 m))
            (setq a (cons (car l) a)
                  l (cdr l)
                  m (1- m)
        (setq b (cons (reverse a) b)
              a nil
    (reverse b)
(defun c:try1 (/ f dataline lst str lst2 lst3 lst4)
(setq f (open "C:\\Trudy-menu\\Lisp\\all_Lisp\\3d_arc\\try1.csv" "r"))
  (while
    (setq lst (cons dataline lst))
  (setq lst (reverse lst))
(repeat (- (length lst) 1)
	(setq str (T:spaceremover (car (cdr lst))))
 		(setq lst2 nil)
        (setq i 0 n (strlen " "))
			(while (setq j (vl-string-search " " str i))
				   (setq lst2 (cons (atof (substr str (1+ i)(- j i))) lst2)
								i (+ j n)
		(setq lst2 (reverse (cons (atof (substr str (1+ i))) lst2)))
		(setq lst3 (cons lst2 lst3))
		(setq lst (cdr lst))
(setq lst4 (LM:group<n (reverse lst3) 3))
(repeat (length lst4)
	(if (= (length (car lst4)) 3)
				(command "_ucs" "_3p" (nth 0 (car lst4)) (nth 1 (car lst4)) (nth 2 (car lst4)))
				(command "arc" (trans (nth 0 (car lst4)) 0 1) (trans (nth 1 (car lst4)) 0 1) (trans (nth 2 (car lst4)) 0 1))
	(setq lst4 (cdr lst4))
(close f)
Edited by Trudy
  • Thanks 1
(defun c:rects ()
(setq x 1)
(setq a 0)
(setq b 0)
(setq c 0)
        (setq c dataline)
        (princ a)
        (princ b)
        (princ c)
    (setq a dataline)
    (setq b dataline)
(setq x (+ 1 x))
(close f)
Sample of CSV file
X,Y,Z
Command: RECTS
Command: _ucs
Command: _arc
Thanks,
Yash
This is not something I do at all. An arc is a 2D entity but can be drawn as a 2d object in a different ucs. Logic (and I could be wrong here) says if you are setting up a ucs from three points, then they are already in that usc and so you don't need to (trans) them. Have you tried just drawing the arc  as
(command "_arc" p1 p2 p3) ?
@dlanorh
I think you are wrong - OP IMHO did just what should with (trans) although - there is missing token "_non" from command call when supplying points to ARC command...
Logic says, 3 points always form a plane. Then from that you can identify the center and everything. I'll type up something shortly
Maybe note the 3pt order for the ucs I think thats were not working
(setq p1 (LIST 221931.63200000036 401253.0739999904 18.268999970437235))
(setq p2 (LIST 221934.92300012588 401257.3900002136 18.269000183106428))
(setq p3 (LIST 221939.25799999948 401259.3889999542 18.23599997806663))
(SETVAR 'OSMODE 0)
(command "ucs" "_3P" p1 P3 P2 )
    (while l
        (setq m n)
                  l (cdr l)
                  m (1- m)
              a nil
    (reverse b)
  (while
 		(setq lst2 nil)
								i (+ j n)
(close f)
Many thanks for the help :)
Hi Yash,
This is a way to do it without using the (command) feature using your original code:
(defun c:rects ( / a b c dataline f x)
    (setq x 1)
    (setq a 0)
    (setq b 0)
    (setq c 0)
	(setq dataline (vl-string-trim " " dataline))
	(cond
	    ((= (rem x 3) 0)
	     (setq c (mapcar 'atof (JH:str->lst dataline ",")))
	     (3Darc a b c)
	    ((= (rem x 3) 1)
	     (setq a (mapcar 'atof (JH:str->lst dataline ",")))
	    ((= (rem x 3) 2)
	     (setq b (mapcar 'atof (JH:str->lst dataline ",")))
	(setq x (+ 1 x))
    (close f)
(defun 3DArc (p1 p2 p3 / cen n1 m1 m2 z1 z2 z3)
    (setq n1 (vx1 (v^v (mapcar '- p1 p2) (mapcar '- p3 p2))))
    (mapcar
	'(lambda (x z)
	     (set z
		  (mapcar
		      '(lambda (y)
			   (if (< (abs y) 1e-8) 0.0 y)
		      (trans x 0 n1)
	(list p1 p2 p3)
	'(z1 z2 z3)
    (setq m1 (mapcar '(lambda (x y) (/ (+ x y) 2.0)) z1 z2)
	  m2 (mapcar '(lambda (x y) (/ (+ x y) 2.0)) z2 z3)
	  cen
	     (inters
		 m1 (polar m1 (+ (* 0.5 pi) (angle z1 z2)) 1)
		 m2 (polar m2 (+ (* 0.5 pi) (angle z2 z3)) 1)
		 nil
    (entmake
	(list
	    '(0 . "ARC")
	    (cons 10 cen)
	    (cons 40 (distance cen z1))
	    (cons 50 (angle cen z3))
	    (cons 51 (angle cen z1))
	    (cons 210 n1)
(defun v^v ( u v )
    (list
        (- (* (cadr u) (caddr v)) (* (cadr v) (caddr u)))
        (- (* (car  v) (caddr u)) (* (car  u) (caddr v)))
        (- (* (car  u) (cadr  v)) (* (car  v) (cadr  u)))
(defun vx1 ( v )
    (   (lambda ( n ) (if (equal 0.0 n 1e-10) nil (mapcar '/ v (list n n n))))
        (distance '(0.0 0.0 0.0) v)
;; JH:str->lst --> Jonathan Handojo
;; Parses a string into a list using a specified delimiter
;; str - string to parse
;; del - delimiter string
(defun JH:str->lst (str del / l rtn src)
    (setq l (1+ (strlen del)))
    (while (setq src (vl-string-search del str))
	(setq rtn (cons (substr str 1 src) rtn)
	      str (substr str (+ src l))
    (reverse (cons str rtn))
Heck why am I even doing so much work for something that can be solved using the (command) feature, lol
Edited by Jonathan Handojo
  • Thanks 1
