Require lisp to draw horizontal curve in AutoCAD + report
Ish
Dear team,
I need a lisp program to draw horizontal curve of a road in AutoCAD.
I will enter radius , curve length, tangent, chord length, angle etc then draw automatically.
And if I have already draw horizontal curve I need full report in Excel or notepad.
Thanks
11 hours ago, Ish said:
Good people always help
That is a bold statement for someone who seems to only visit this forum to demand free Lisp programs.
Edited by Roy_043
You mean something like this, have a go at writing something its just the arc properties,
(entget (car (entsel "\Pick an arc")))
((-1 . <Entity name: 82b6b060>)
(0 . "ARC")
(410 . "Model")
(8 . "0")
(10 116.242228560598 54.7129767932515 0.0)
(40 . 20.0)
(50 . 1.30406490850272)
(51 . 2.48257365707))
Yes boss:
Mainly I need  for output report.sir
TL - tangent length
CL - chord length
R - Radius
LCC- length of curve
E - external distance
M - mid ordinate
Angle
Sir
Thanks for your good reply and value of time.
This is for output report of curve sir.
Edited by Ish
38 minutes ago, Jonathan Handojo said:
After everything is entered, where should the curve be inserted?
After I select arc. Sir
Edited by Ish
Arc length is rad x theta (angle) or get length property.
Chord distance pt1 -> pt2
Tangent
(setq hyp (/ arcrad (cos (/ angdiff 2.0))))
(setq tang (sqrt (- (* hyp hyp) (* arcrad arcrad))))
Mid know tangent and angles
E know 1/2 angle and rad distance -> mid
Tangent
I will be very thanksful to you,
Please make a complete lisp sir
Thanks u
  • Dislike 1
The idea is have a go yourself as you can see I have something it was done back in 1990 .
Just start with entsel arc and use VLa-get- the correct property.
Command: DUMPIT
Select object: ; IAcadArc: AutoCAD Arc Interface
; Property values:
;   Application (RO) = #<VLA-OBJECT IAcadApplication 00007ff6f8381e30>
;   ArcLength (RO) = 183.377
;   Area (RO) = 4590.91
;   Center = (-27947.5 146195.0 0.0)
;   Document (RO) = #<VLA-OBJECT IAcadDocument 000002577e00d318>
;   EndAngle = 3.16225
;   EndPoint (RO) = (-28039.0 146193.0 0.0)
;   EntityTransparency = "ByLayer"
;   Handle (RO) = "71CB7F"
;   HasExtensionDictionary (RO) = 0
;   Hyperlinks (RO) = #<VLA-OBJECT IAcadHyperlinks 000002577f82e058>
;   Layer = "3-PROJ_Área Abrangência PLC"
;   Linetype = "CONTINUOUS"
;   LinetypeScale = 1.0
;   Lineweight = -1
;   Material = "ByLayer"
;   Normal = (0.0 0.0 1.0)
;   ObjectID (RO) = 42
;   ObjectName (RO) = "AcDbArc"
;   OwnerID (RO) = 43
;   PlotStyleName = "ByLayer"
;   Radius = 91.4795
;   StartAngle = 1.15767
;   StartPoint (RO) = (-27910.8 146279.0 0.0)
;   Thickness = 0.0
Lol, I just love how no one is actually offering any help despite this being a ridiculously easy task, haha...
Friend... "Good people always think twice before helping". There's a reason no one is helping you.
As much as I'm being an annoying pest, this is all you're getting from me. The rest is on your own.
(defun c:arcdetails ( / arc)
    (and
	(setq arc (car (entsel "\nSelect arc <exit>: ")))
	((lambda (x / ep sp)
	     (princ
		 (strcat
		     "\nArc Start Point: " (vl-prin1-to-string (setq sp (vlax-get x 'StartPoint)))
		     "\nArc Mid Point: " (vl-prin1-to-string (vlax-curve-getPointAtParam x (* 0.5 (vlax-curve-getEndParam x))))
		     "\nArc End Point: " (vl-prin1-to-string (setq ep (vlax-get x 'EndPoint)))
		     "\nArc Radius: " (rtos (vla-get-Radius x) 2)
		     "\nArc Length: " (rtos (vla-get-ArcLength x) 2)
		     "\nChord Length: " (rtos (distance sp ep) 2)
	    (vlax-ename->vla-object arc)
    (and
	     (princ
		 (strcat
Sir , this working very nice for me.
But still
TL - tangent length
M - mid ordinate and
Angle .
Value is missing, please add these also sir.
Thanks
Like I said earlier, the above is all you're getting from me. It's not that hard to get those (if you actually know how to code). Why don't you give it a shot first before demanding others for answers? This is a forum where you seek help when you're stuck, not where you seek for free codes specifically for you.
All others, if you think I'm wrong by any means, please correct me (or feel free to ban me even... pleasure serving with CADTutor!)
  • Like 2
Just get your engineering or surveying handbook out and look up horizontal curve you will find a diagram that has all the variables and how to work out the answers, just draw it and think about old school sin cos pythagoras etc.
This was like 1 minute on Google
Edited by BIGAL
  • Thanks 1
