Create polygon from GRID
Trudy
Hello, i want to ask for help with creating closed polygon from Grid lines with lisp.
Regards Trudy :)
Edited by Trudy
I'd recommend that you create single one, set variable (setq el (entlast)) and then do ARRAYCLASSIC - Rectangular option... Finally you iterate through newly created entities and change numbers in texts :
(setq k 1)
(while (setq el (entnext el))
  (if (wcmatch (cdr (assoc 0 (entget el))) "*TEXT")
    (entupd (cdr (assoc -1 (entmod (subst (cons 1 (strcat (substr (cdr (assoc 1 (entget el))) 1 (1- (strlen (cdr (assoc 1 (entget el)))))) (itoa (setq k (1+ k))))) (assoc 1 (entget el)) (entget el))))))
Edited by marko_ribar
