SW Motion Analysis - Springs not working
Hi,
I'm having an issue with the SolidWorks Motion add-in. I'm trying to model a pretty simple mass-spring system, but when I insert a spring to the system, define its characteristics etc... it disappears from view. As in it disappears and when I play the animation, there is no motion whatsoever. I've attached screenshots, the first shows what I see while modifying the spring and the second shows what happens when I verify the changes. You can also see that the force condition I added is greyed out and I'm not sure why this is either.
This seems pretty straightforward as far as issues go but I really don't know why this happens. Can someone help? Thank you in advance.
https://1drv.ms/u/s!AkLiAcqKqEBjgoUxA8EsYkzX9xWl3Q?e=dWcxAn  #1
https://1drv.ms/u/s!AkLiAcqKqEBjgoUydgQ6EkxcrRKUKQ?e=dt08zB #2
