Return list in pairs
gsc
Hi,
I have a lisp function which returns a list of dynamic block properties:
(defun getdynprops ( blk / lst )
    (vl-load-com)
    (setq lst
        (mapcar '(lambda ( x ) (cons (vla-get-propertyname x) (vlax-get x 'value)))
            (vlax-invoke (vlax-ename->vla-object blk) 'getdynamicblockproperties)
Since my dynamic block only has a number of "polar stretch" parameter/actions , which exist of a Distance and an Angle property. The function returns a list like:
((<Angle1> . <Value>) (<Distance1> . <Value>) (<Angle2> . <Value>) (<Distance2> . <Value>) (<Angle3> . <Value>) (<Distance3> . <Value>) ... )
But my goal is to pair the Angle and Distance property in the list. e.g.
( ((<Angle1> . <Value>) (<Distance1> . <Value>)) ((<Angle2> . <Value>) (<Distance2> . <Value>)) ((<Angle3> . <Value>) (<Distance3> . <Value>)) ... )
How do I achieve this?
Untested.
(defun getdynprops (blk / r)
  (mapcar '(lambda (x / l)
             (if l (setq r (cons (append l (cons (vla-get-propertyname x) (vlax-get x 'value))) r) l nil)
               (setq l (cons (vla-get-propertyname x) (vlax-get x 'value)))
  r
  ) (vl-load-com)
Here's another assuming that you have ALL matching Angle/Distance properties.
(defun getdynprops (blk)
  (mapcar '(lambda (x) (cons (vla-get-propertyname x) (vlax-get x 'value)))
(if (setq r (getdynprops (car (entsel))))
  (progn (setq r (vl-sort r '(lambda (r j) (< (car r) (car j)))))
	 (mapcar '(lambda (r j) (list r j)) r (member (nth (/ (length r) 2) r) r))
22 hours ago, Tharwat said:
Untested.
  r
  ) (vl-load-com)
This returns all NIL values
For the IF part you could also use a Lee Mac sub function:
(defun group-n ( l n / r )
    (if l
        (cons
            (reverse (repeat n (setq r (cons (car l) r) l (cdr l)) r))
            (group-n l n)
    (if l
        (cons
            (group-n l n)
The list still has to be sorted alphabetically and broken in two so not sure how that would work per your original example.
Edited by ronjonp
The functions posted so far rely on a number of assumptions:
  • All dynamic block properties returned by the ActiveX getdynamicblockproperties method are either Angle or Distance parameters (in reality, there will also be many origin parameters)
  • There are equal numbers of Angle & Distance parameters, perfectly paired
As such, if you wanted to be certain that you were pairing a parameter named "Angle1" with a parameter named "Distance1" and so on, you may need to use somewhat uglier code such as the following:
(defun getdynprops ( blk / ang dis nme )
    (foreach  prp (reverse (vlax-invoke blk 'getdynamicblockproperties))
        (setq nme (strcase (vla-get-propertyname prp) t))
        (cond
            (   (wcmatch nme "angle#*")
                (setq ang (cons (cons nme (vlax-get prp 'value)) ang))
            (   (wcmatch nme "distance#*")
                (setq dis (cons (cons nme (vlax-get prp 'value)) dis))
    (vl-remove-if-not 'cadr
        (mapcar '(lambda ( a ) (list a (assoc (strcat "distance" (substr (car a) 6)) dis))) ang)
        (cond
Thanx man this is working, although I had to change the wcmatch search string "angle#*" and "distance#*" to "angle*" and "distance*", otherwise I got al nil values
