JovanG
How to know if a DXF property exist in an autocad object with lisp
JovanG
Hi dear team. Wish you a great day
I was wondering if there is a way to know if a DXF property exist on selected objects:
For example:
(setq ss (ssget "something"))
(if (exist DXF code 3 in ss) (prompt "\nThe DXF code 3 exist in selected object") (prompt "\nThe DXF code 3 doesn`t exist in selected object"))
Share this post
Link to post
pkenewell
@JovanG Look at using (assoc), it returns nil if the DXF code is not present.
Example:
(assoc 3 (entget (car (entsel))))
Paste this at the command line and select a longer mtext and a short mtext
If you are iterating through the selection set it would be something like this snippet of code:
(defun massoc (key alist / x nlist)
   (foreach x alist
      (if
         (eq key (car x))
         (setq nlist (cons x nlist))
   (reverse nlist)
) ;defun
(setq cnt -1)
(repeat (sslength ss)
  (setq en (entget (ssname ss (1+ cnt))))
  (if (assoc 3 en)
         (setq str
             (apply 'strcat
			    (cons
                   (mapcar 'cdr (massoc 3 en))
                   (cdr (assoc 1 en))
         ; .. do something ..
        (setq str (cdr (assoc 1 en)))
EDIT - corrected! The (apply) statement should've has 'strcat, not 'append
Edited by pkenewell
Share this post
Link to post
JovanG
Excellent! Thank you very much @pkenewell. That was just what I needed
Share this post
Link to post
