its_ikon Posted January 29, 2021 Posted January 29, 2021 When opening a file, the command prompt continuously cycles through regenerating model over and over and over again. This is non stop until a command is started and canceled or sometimes hitting escape. Here is the weird thing, completely random and not all the same files. Recreated the profile, used standard install with no custom anything, audit, resetting target, export to autocad, recover, layer properties closed, repair, reinstall, etc. I can e-transmit and open the file on my home computer and not get the issue, so that is one thing I am trying to work off of. Anyone else have ideas? Went from AutoCAD 2018 to 2021 when the issue started. Quote
Cad64 Posted January 29, 2021 Posted January 29, 2021 So, you're using 2021? Your profile says you're using 2010. You could try setting the REGENAUTO variable to 0 and see if that stops the message from happening. This means you will have to perform Regen's manually though, which isn't a big deal, just something you will need to remember to do. I work on files that are saved on my client's server and I found that turning off REGENAUTO helps speed up panning, zooming and switching back and forth between layout tabs. It may or may not help with opening files though. Just something to try. Quote
RobDraw Posted January 29, 2021 Posted January 29, 2021 It almost sounds like AutoCAD is trying to find something that the file is referencing and can't find it. Is the home computer using the same version of AutoCAD? Quote
tombu Posted January 29, 2021 Posted January 29, 2021 Have you tried to Audit or Recover the drawing? Quote
