Merging Blocks with Attributes
vasanthsv84
Good day everyone,
 I like to merge three blocks attributes to one block with attributes. I'm not good at VBA. I hope someone correct the below code for me. Thanks
Public Sub Merge_LnBLk()
 Dim ss As ZcadSelectionSet
 Dim UNode As ZcadText
 Dim UGL As ZcadText
 Dim UIL As ZcadText
 Dim DNode As ZcadText
 Dim DGL As ZcadText
 Dim DIL As ZcadText
 Dim LnLen As ZcadText
 Dim Size As ZcadText
 Dim GetPt As Variant
 Dim BlkName As String
 Dim NodeBlk As ZcadBlockReference
 Dim FromBlk As ZcadBlockReference
 Dim ToBlk As ZcadBlockReference
 Dim SizeBlk As ZcadBlockReference
 Dim objAttribs As Variant
 Dim FromobjAttribs As Variant
 Dim ToobjAttribs As Variant
 Dim SizeobjAttribs As Variant
 On Error Resume Next
 ThisDrawing.SelectionSets("s").Delete
 On Error GoTo 0
 Set ss = ThisDrawing.SelectionSets.Add("s")
 ss.SelectOnScreen
 Set FromBlk = ss.Item(0)
 Set ToBlk = ss.Item(1)
 Set SizeBlk = ss.Item(2)
 GetPt = ActiveDocument.Utility.GetPoint(, "Pick where the block to be inserted")
 BlkName = "LNNode"
 Set NodeBlk = ActiveDocument.ModelSpace.InsertBlock(GetPt, BlkName, 1, 1, 1, 0)
 FromobjAttribs = FromBlk.GetAttributes()
 UNode.TextString = FromobjAttribs(0)
 UGL.TextString = FromobjAttribs(1)
 UIL.TextString = FromobjAttribs(2)
 ToobjAttribs = ToBlk.GetAttributes()
 DNode.TextString = ToobjAttribs(0)
 DGL.TextString = ToobjAttribs(1)
 DIL.TextString = ToobjAttribs(2)
 SizeobjAttribs = SizeBlk.GetAttributes()
 LnLen.TextString = SizeobjAttribs(0)
 Size.TextString = SizeobjAttribs(1)
 objAttribs = NodeBlk.GetAttributes()
 objAttribs(0).TextString = UNode
 objAttribs(1).TextString = UGL
 objAttribs(2).TextString = UIL
 objAttribs(3).TextString = DNode
 objAttribs(4).TextString = DGL
 objAttribs(5).TextString = DIL
 objAttribs(6).TextString = LnLen
 objAttribs(7).TextString = Size
 NodeBlk.Update
End Sub
TestBlocks.dwg
Edited by vasanthsv84
On 2/2/2021 at 12:25 PM, vasanthsv84 said:
Good day everyone,
 Dim UGL As ZcadText
 Dim UIL As ZcadText
 Dim DGL As ZcadText
 Dim DIL As ZcadText
 On Error GoTo 0
 ss.SelectOnScreen
 BlkName = "LNNode"
 NodeBlk.Update
End Sub
Here the code revised:
You have to assign the Attribute Value stored into the Textstring Array property into a Variable and then assign the newblock attribute value as the variable.
 Dim ss As AcadSelectionSet
 Dim UNode As Variant 'AcadText
 Dim UGL As Variant 'AcadText
 Dim UIL As Variant 'AcadText
 Dim DNode As Variant 'AcadText
 Dim DGL As Variant 'AcadText
 Dim DIL As Variant 'AcadText
 Dim LnLen As Variant 'AcadText
 Dim Size As Variant 'AcadText
 Dim NodeBlk As AcadBlockReference
 Dim FromBlk As AcadBlockReference
 Dim ToBlk As AcadBlockReference
 Dim SizeBlk As AcadBlockReference
 On Error GoTo 0
 ss.SelectOnScreen
 BlkName = "LNNode"
 UNode = FromobjAttribs(0).TextString
 UGL = FromobjAttribs(1).TextString
 UIL = FromobjAttribs(2).TextString
 DNode = ToobjAttribs(0).TextString
 DGL = ToobjAttribs(1).TextString
 DIL = ToobjAttribs(2).TextString
 LnLen = SizeobjAttribs(0).TextString
 Size = SizeobjAttribs(1).TextString
 NodeBlk.Update
End Sub
Edited by PeterPan9720
