How could I change this:
Quote
(setq Website (strcat "https://websoilsurvey.nrcs.usda.gov/app/WebSoilSurvey.aspx?location=((" LONG " " LAT "," LONG3 " " LAT3 "))"))
(command "_browser" Website) ;;;;How can I get the above address to be copied to the clip board?
Instead of opening the browser to the website, just copy the link to a clip board?
There are some users that like to use either chrome, firefox, or what not. I figured they could paste it in whatever browser.
(defun c:soil (/ COORDS LONGLAT LONG LAT PROJDEST PROJSRC COORDS2 LONGLAT2 LONG2 LAT2 COORDS3 LONGLAT3 LONG3 LAT3 COORDS4 LONGLAT4 LONG4 LAT4 )
(setq PROJSRC (ade_projgetwscode))
(if (/= (getvar "ctab") "Model") (command "_mspace"))
(ade_projsetsrc PROJSRC)
(ade_projsetdest "LL84")
(setq COORDS (getpoint "\nPick the Bottom Left Corner of Area of Interest within Modelspace: "))
(setq LONGLAT (ade_projptforward COORDS))
(setq LONG (car LONGLAT))
(setq LONG (rtos LONG 2 6))
(setq LAT (car (cdr LONGLAT)))
(setq LAT (rtos LAT 2 6))
(setq PROJDEST (ade_projgetinfo "LL84" "description"))
(princ (strcat
"\n X,Y: " (rtos (car COORDS) 2 6) "," (rtos (cadr COORDS) 2 6)
"\n Projection SOURCE :  " PROJSRC
"\n Projection CIBLE(Target) :  " PROJDEST
"\n Longitude,Latitude: " LONG "," LAT
"\n"))
(setq COORDS3 (getpoint "\nPick the Top Right Corner of Area of Interest within Modelspace: "))
(setq LONGLAT3 (ade_projptforward COORDS3))
(setq LONG3 (car LONGLAT3))
(setq LONG3 (rtos LONG3 2 6))
(setq LAT3 (car (cdr LONGLAT3)))
(setq LAT3 (rtos LAT3 2 6))
(princ (strcat
"\n X,Y: " (rtos (car COORDS3) 2 6) "," (rtos (cadr COORDS3) 2 6)
"\n Longitude,Latitude: " LONG3 "," LAT3
"\n"))
(princ))
thanks for the direction.
Have you done a search? Copy to clipboard has been answered many times before.
thank you ronjonp.
I found code that leemac posted.
I am guessing i would need to (LM:copytoclipboard "setq Website (strcat "https://websoilsurvey.nrcs.usda.gov/app/WebSoilSurvey.aspx?location=((" LONG " " LAT "," LONG3 " " LAT3 "))")")
;; Copy to Clipboard  -  Lee Mac
;; Using the same method as MP demonstrates here: http://bit.ly/170kacW
(defun LM:copytoclipboard ( str / clp htm par )
    (if (setq htm (vlax-create-object "htmlfile"))
            (vl-catch-all-apply
               '(lambda ( )
                    (setq par (vlax-get htm 'parentwindow)
                          clp (vlax-get par 'clipboarddata)
                    (vlax-invoke clp 'setdata "Text" str)
            (foreach obj (list clp par htm)
                (if (= 'vla-object (type obj))
                    (vlax-release-object obj)
            str
(vl-load-com) (princ)
(princ (strcat
"\n"))
(princ (strcat
"\n"))
;;(command "_browser" Website) ;;;;How can I get the above address to be copied to the clip board?
(princ))
3 hours ago, rcb007 said:
thank you ronjonp.
            (vl-catch-all-apply
               '(lambda ( )
            str
(princ (strcat
"\n"))
(princ (strcat
"\n"))
(princ))
Not quite .. see below. You should use the VLIDE when editing code .. the color coding really helps point out snafu's.
;; NO GOOD
;; TRY THIS
(LM:copytoclipboard  (strcat "https://websoilsurvey.nrcs.usda.gov/app/WebSoilSurvey.aspx?location=((" LONG " " LAT "," LONG3 " " LAT3 "))")))
Visual of how I trouble shot this:
ah.... so sorry! thank you for the guide! lol. What is it... close but no cigar.
No worries .. just giving you some pointers so you can troubleshoot this stuff for yourself. 🍻
Checked out Browser did not know about it learn something new everyday. Anyway the answer, just need to sort your string out.
(setvar 'filedia 0)
(setq loc "https://www.google.com.au/maps/place/Bennelong Point, Sydney NSW 2000")
(command "browser" loc)
