WHEN I WENT TO SAVE ANY AUTOCAD DRAWINGS IT SHOWS ERROR WRITING/CLOSE FILES. HOW CAN I SOLVE THE PROBLEN IN MY PC.
SUMAN GANGULY
Used to be a problem with AutoSave causing that error or it could be trying to write to a folder without the correct permissions, etc.
You could try to Audit and repair the drawings. Have you tried a new blank drawing to see if there is any problem?
Is your AutoCAD completely updated? What OS are you using? AutoCAD 2007 is pretty old, are you on an older Computer or newer with a recent Windows version?.
