Select Xref Layer to match Source XREF visretain
I did not know if there was a way to perform a visretain to 0, reload xref, then set visretain to 1 for just a selected layer (instead of the whole xref)?
What I have been dealing with lately is a user would change the a linetype and color of (example: property line) from solid line to a phantom line. I would have to to into the plan sheet and the above.
The cheat I have been messing around with is, by changing the layer name. that way it pushes through.
I hope I am explaining this correctly lol.
Does this accomplish the desired result, or have I misunderstood your requirements?
EDIT: The above will reset specific properties of all layers, but could be modified to target a specific layer if necessary.
Edited by Lee Mac
Thank you for the feedback! I was able to load the routine in. I did "RXL" then selected the xref layer i wanted to change back to make the source dwg. However, when i did that, it reset the whole xref dwg to match the source. (Just to make sure i kinda make sense. I turned whole xref dwg to color blue and continuous linetype). It did reset it to match the source dwg.
Again, i could have not done the command correctly.
For single layers I use the routine by Joe Burke posted here:
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/revert-layer/m-p/1278570#M176366
Unfortunately the autodesk forum destroyed the formatting & removed all line breaks. My version is below, thought it might have some changes from Joe's original code
;;; Reply-To: "Joe Burke" <jobu...@hawaii.rr.com>
;;; From: "Joe Burke" <jobu...@hawaii.rr.com>
;;; Newsgroups: autodesk.autocad.customization
;;; Subject: Re: Revert Layer
;;; Date: Fri, 25 Mar 2005 02:23:33 -1000
;;; Jason,
;;; Here's what I use. It's designed to do what you asked.
;;; It's not what it should be if you happen to pick an object in an xref on layer zero
;;; or defpoints. But it met my needs at the time.
;;; I haven't used it much since, so it hasn't had much testing. Let me know if you find
;;; any problems.
;;; Joe Burke  4/13/2004
;;; update the selected xref layer color and linetype in the
;;; active file from xref source file
(defun c:XrefReloadLayer ( / *Error* *acad* doc documents layers elst vobj
                             layname layobj pos xlayname xblk xblkname path
                             xdoc xlayers xlayobj xclr xltyp xpsty)
  (defun *Error* (Msg)
   (cond
    ((or (not Msg)
         (member Msg '("console break"
                       "Function cancelled"
                       "quit / exit abort"))))
    ((princ (strcat "\nError: " Msg)))
  (setq *acad* (vlax-get-acad-object)
        doc (vla-get-activedocument *acad*)
        documents (vla-get-Documents *acad*)
        layers (vla-get-Layers doc)
  (while
    (or
      (not (setq elst (nentsel "\nSelect object on xref layer to reset color & linetype: ")))
      (not (eq 'ENAME (type (last (last elst)))))
      (not (vlax-property-available-p
           (vlax-ename->vla-object (last (last elst))) 'Path))
    (princ "\nMissed pick or xref not selected: ")
  ) ;_while
  (and
    (setq vobj (vlax-ename->vla-object (car elst)))
    (setq layname (vlax-get vobj 'Layer))
    (if (equal "0" layname) ;obj is probably in a block
        (setq vobj (vlax-ename->vla-object (car (last elst))))
      T
    (setq layobj (vla-item layers layname))
    (if (not (vl-string-search "|" layname))
        (princ "\nCannot determine xref layer name... exiting. ")
        (exit)
      T
    ) ;_if
    (setq pos      (vl-string-search "|" layname))
    (setq xlayname (substr layname (+ 2 pos)))
    (setq xblk     (vlax-ename->vla-object (last (last elst))))
    (setq xblkname (vlax-get xblk 'Name))
    (setq path     (XrefReloadLayer_get-xref-path xblkname))
    (setq xdoc     (XrefReloadLayer_DocAtPath path))
    (setq xlayers  (vla-get-Layers xdoc))
    (setq xlayobj  (vla-item xlayers xlayname))
    (setq xclr     (vlax-get xlayobj 'Color))
    (setq xltyp    (vlax-get xlayobj 'Linetype))
    (setq xpsty    (vlax-get xlayobj 'PlotStyleName))
    (vlax-release-object xdoc)
    (not (vlax-put layobj 'Color xclr))
    (not (vlax-put layobj 'Linetype xltyp))
    (not (vlax-put layobj 'PlotStyleName xpsty))
  ) ;and
  (vla-regen doc acActiveViewport)
  (princ (strcat "\nLayer " layname " reset to color: " (vl-princ-to-string xclr) ", linetype: "(vl-princ-to-string xltyp)", plotstyle: "(vl-princ-to-string xpsty)))
  (*Error* nil)
) ;end
;; argument: full path
;; returns a document object (srcdoc)
;; either an open document or an ODBX doc
(defun XrefReloadLayer_DocAtPath ( path / *acad* documents srcdoc )
        documents (vla-get-documents *acad*)
  ;check the documents collection
  (vlax-for x documents
    (if (= path (vlax-get x 'FullName))
      (setq srcdoc x)
  ;if not in documents collection, use ObjectDBX
  (if (null srcdoc)
    (cond
      ((> (atoi (getvar "AcadVer")) 15)
        (setq srcdoc
          (vla-GetInterfaceObject *acad* "ObjectDBX.AxDbDocument.16"))
        (vla-open srcdoc path)
      (T
        (if (not
         (vl-registry-read "HKEY_CLASSES_ROOT\\ObjectDBX.AxDbDocument\\CLSID"))
           (startapp "regsvr32.exe"
             (strcat "/s \"" (findfile "axdb15.dll") "\""))
        (setq srcdoc (vla-GetInterfaceObject *acad* "ObjectDBX.AxDbDocument"))
  srcdoc
) ;end
;; If an xref is not found in the saved path AutoCAD searches
;; the whole support path. By Stephan Koster 2001
;; argument: an xref block name
;; returns the full path to the xref if successful
(defun XrefReloadLayer_get-xref-path (blockname / data path saved_path pos)
 (cond ((not (setq data (tblsearch "block" blockname))))
       ;; Does the block exist
       ((/= (logand (cdr (assoc 70 data)) 4) 4))
       ;; Is it an xref
       ((and (setq saved_path (cdr (assoc 1 data)))
             (setq path (findfile saved_path))
             ;; Can it be found on the saved path
       ((not (setq pos (vl-string-position (ascii "\\") saved_path 1 T))))
       (T (setq path (findfile (substr saved_path (+ pos 2)))))
       ;; Can it be found somewhere else in the search path
 path
Edited by dan20047
