Change LineTypeScale of Polyline After Drawing
JulianSmith
Hello,
Trying to get a LISP routine to work to set the LineTypeScale of an object after I have drawn it. I can get all of the commands to work manually, but I can't get them to work together. I think it might have something to do with the pause statement I use to get user  input when drawing the polyline. Does anyone have a suggestion for how I can better set the LineTypeCale for this object? I don't want to set the LineTypeScale for the entire drawing. Many thanks. Cheers.
(Defun C:TestPl ()
    (setvar "CMDECHO" 0)
    (setq plccLayer (getvar "clayer"))
    (COMMAND "-LAYER"         "MAKE"             "FIBER"     "COLOR"         "130" "FIBER"
                   "Ltype"  "FENCELINE1" "FIBER"     ""                     "PLINEWID"     "0.015"         "PLINE"
                     PAUSE
    (setvar "clayer" plccLayer)
    (setvar "PLINEWID" 0.0)
      (setq ss (ssget "L"))
        (command "change" ss "" "p" "s" 0.25 "")
The reason is because it tries to run the other commands before you finish the "pline" command. You need to delay the operation of the rest of the routine until it is finished. It does not do this for you with only 1 PAUSE option.
Try This - note the "cmdactive" loop to pause the "pline" command until you are finished drawing the polyline (see my comments for other improvements):
(Defun C:TestPl (/ plccLayer oecho oplwid ss); Localize your variables
    (setq plccLayer (getvar "clayer") oplwid (getvar "plinewid") oecho (getvar "cmdecho"))
    (setvar "plinewid" 0.015) ;; Don't use command to set system variables.
    ;; You want CMDECHO set to 1 here so you can see pline prompts.
    ;; FYI - the "dot" before the command ensures that the true command is used (not redefined),
    ;; the "underscore" will translate command names and options for international versions.
    (COMMAND "._-LAYER" "_M" "FIBER" "_C" "130" "" "_L" "FENCELINE1" "" ""
             "._PLINE"
    ;; This loops the pause until the command is over.
    (while (= (logand (getvar "cmdactive") 1) 1)
		 (command pause)
    ;; reset system variable back to original values.
    (setvar "PLINEWID" oplwid)
    ;; Set cmdecho here to 0 to not see the change command.
    (command "._Change" ss "" "_P" "_S" 0.25 "")
    ;; Reset cmdecho back to original value.
    (setvar "cmdecho" oecho)
Edited by pkenewell
  • Thanks 1
4 hours ago, pkenewell said:
Thanks pkenewell; it worked perfect! Thanks also for the lesson. I knew it was going to be a loop, I just couldn't figure out where to put it.
