Is it possible to convert an ellipse to a circle with autolisp
JovanG
Hello everyone.
I wonder if there is a way to convert an ellipse to a circle with the help of autolisp. I have a DWG that contains some circles and ellipses in coordinate representation. But I have noticed that even when the minor radius is equal to the major radius (apparently a circle), the center coordinate that appears in the properties is not the same that I have inserted. So, I believe that if I change the ellipse to circle problem will be solved.
Thank you in advance for your time and help. Have a nice day
Here is a function to do it. Note - this only works if the Major to Minor radius ratio is 1 (in other words - looks like a circle). If you want it different then let me know.
(defun C:EL2CIR (/ cen cnt en ent maj mad)
   (if (setq ss (ssget '((0 . "ELLIPSE"))))
      (repeat (setq cnt (sslength ss))
         (setq ent (entget (setq en (ssname ss (setq cnt (1- cnt)))))
               cen (cdr (assoc 10 ent))
               maj (cdr (assoc 11 ent))
               mad (distance '(0.0 0.0 0.0) maj)
         (if (= (cdr (assoc 40 ent)) 1.0)
               (command "._circle" "_non" cen mad)
               (entdel en)
  • Like 2
               (entdel en)
Nice :) .. FWIW if you create the circle like so it will retain all by object properties too:
(defun c:el2cir	(/ cen cnt en ent maj mad)
      (setq ent	(entget (setq en (ssname ss (setq cnt (1- cnt)))) '("*"))
	;; (progn (command "._circle" "_non" cen mad) (entdel en))
	(and (entmake
	       (append
		 '((0 . "CIRCLE"))
		 (vl-remove-if '(lambda (x) (vl-position (car x) '(-1 0 100 330 5 11 40 41 42))) ent)
		 (list (cons 40 mad))
	     (entdel en)
  • Thanks 1
Very Nice @ronjonp! Very efficient way to retain the original layer, linetype, color, etc.
54 minutes ago, JovanG said:
so I just deleted the conditional and it works great.
FWIW rather than deleting the conditional, you could use the "equal" function with a fuzz factor, if the ellipses are only off by a small amount. depends on whether you need to prevent changing an ellipse that is supposed to be an ellipse.
I.e. this:
(setq fuz 0.005) ;; Set error fuzz value
(if (equal (cdr (assoc 40 ent)) 1.0 fuz)
instead of this:
Edited by pkenewell
That`s a great idea @pkenewell, thank you a lot for your help.
  • 1 year later...
