I  have sent the attached .dxf files to be cut out on a CNC machine, but the operator says it is full of 3D data that needs to be removed first. I  have never used 3D, so wonder how it got in there, and how to remove it. I  have even tried locking off the hidden lines and dimensions  as shown in one file, to no avail
Hoping someone can please assist
Tray 141 x 45_2016.dxf
Tray 141 x 45_2018_layers deleted.dxf
Edited by JoeS09
You have a lot of blocks and other unused elements in your drawing. You should run the PURGE command and remove these things from the drawing.
Perhaps when you make the DXF file, you should choose the objects instead of making a DXF of the whole file. That way you would know what was in the file.
