Hey, I am using Autocad 2018
Trying to create a dynablock for arranging my folding lines on sheet metal, but can't get to make it just as i wanted.
Picture No 1 is the original gap between my part and folding flap, which has 0.8mm of thickness, but I am trying to make it reinforced by adding 4mm bridges in between the gaps like in the Picture No 2. At first, I used DIVIDE command to divide the gap into equal pieces, and made those bridges manually. But there are thousands of them and I am in a really tight schedule to complete. I tried to create a dynablock, which I am not really good at making, but I could not make it work properly. I added the ARRAY action, but end of the array line overlapped with those little yellow lines just as in the Picture No 3. While arranging these gaps, the bridges between the gaps supposed to be 4mm long, but the length of the gaps are not really important. They can vary between 15-25mm, even more.
I am not sure if there is a specific way to do just as I asked. But I am really welcome to any solution which makes this process faster. Hope I could explain my problem correctly. Thanks all in advance.
Edited by paradiddle
There is no problems doing slots picking say a line, say in lisp need a few rules gap min max length and width etc.
