Hunter Posted February 9, 2009 Posted February 9, 2009 Hi all: Can someone give me a lisp which can: 1.calculate each area of region or polyline seleled by user and write the area in text . 2.calculate the sum of all areas and write in text. 3.export each to Excel. Actually I found the function 「Area Calcutaion」of CadTools almost met my need, but it only works for polylines not for regions... Much appreciate~ Li Quote
DECHAL Posted February 9, 2009 Posted February 9, 2009 Check out Ronald Meneja's routine for calculating the area of a closed polyline over at cadalyst magazine's CAD Tips. Tip #2292 dated 01-Jun-2008. Link: http://cadtips.cadalyst.com/content/...osed-polylines Regards, DECHAL. Quote
Hunter Posted February 9, 2009 Author Posted February 9, 2009 Thanks... but the code cannot work for region, neither can it export the notation to Excel... Quote
wizman Posted February 9, 2009 Posted February 9, 2009 here's an update, works now for region, circle,ellipse and and closed spline ;;; CADALYST 07/08 www.cadalyst.com/code ;;; Tip 2292: AreaRon.lsp Area of Closed Polylines (c) 2008 Ronald Maneja (Wizman) ;;; PRODUCES TEXT CONTAINING AREA OF SELECTED CLOSED POLYLINES ;;; AND PUTS THEM IN AREARON LAYER ;;; CREATED BY RON MANEJA 31JAN08 ;;; USER INPUTS: SCALE, POLYLINE SELECTION ;;; ;;; VERSION 1.1 (09FEB09): ADDED AREA FOR REGIONS, SPLINE, CIRCLE & ELLIPSE ;;; (defun C:AREARON (/ allx ally areaobj counter ctr el entity-name entnamevla mysset prec_temp pt reg_centroid temp tst vertex x y oldlayer oldsnap temperr traperror blpt cir_center el_center maxpt minpt spl_center trpt ) (defun set_var () (setvar 'cmdecho 0) (setq oldlayer (getvar "clayer")) (setq oldsnap (getvar "osmode")) (setq temperr *error*) (setq *error* traperror) (setvar "osmode" 0) ) (defun traperror (errmsg) (command nil nil nil) (if (not (member errmsg '("console break" "Function Cancelled")) ) (princ (strcat "\nError: " errmsg)) ) (command "_.undo" "end") (setvar "clayer" oldlayer) (setvar "osmode" oldsnap) (setvar "cmdecho" 1) (princ "\nError Resetting Enviroment ") (setq *error* temperr) ) (defun reset_var () (setq *error* temperr) (setvar "clayer" oldlayer) (setvar "osmode" oldsnap) (command "_.undo" "end") (setvar "cmdecho" 1) ) (vl-load-com) (set_var) (command "_.undo" "be") (if (tblsearch "Layer" "AREARON") (command "._layer" "_thaw" "AREARON" "_on" "AREARON" "_unlock" "AREARON" "_set" "AREARON" "") ;_ closes command (command "._layer" "_make" "AREARON" "_color" 1 "AREARON" "") ;_ closes command ) (if (null sch) (setq sch 1.0) ) (initget 6) (setq temp (getreal (strcat "\nENTER SCALE <" (rtos sch 2 2) ">: " ) ) ) (if temp (setq sch temp) (setq temp sch) ) (if (null precision) (setq precision 1) ) (initget 6) (setq prec_temp (getint (strcat "\nHOW MANY DECIMAL PLACES?: <" (rtos precision 2 2) ">: " ) ) ) (if prec_temp (setq precision prec_temp) (setq prec_temp precision) ) (prompt "\nSELECT CLOSED POLYLINES/SPLINES, REGION, CIRCLE & ELLIPSE:> ") (setq mysset (ssget '((-4 . "<or") (-4 . "<and") (0 . "LWPOLYLINE") (70 . 1) (-4 . "and>") (-4 . "<and") (0 . "SPLINE") (70 . 11) (-4 . "and>") (0 . "REGION") (0 . "CIRCLE") (0 . "ELLIPSE") (-4 . "or>") ) ) counter 0 ) (if mysset (progn (while (< counter (sslength mysset)) (setq entity-name (ssname mysset counter) EL (entget entity-name) entnamevla (vlax-ename->vla-object entity-name) areaobj (vla-get-area entnamevla) ) (cond ((eq (cdr (assoc 0 el)) "LWPOLYLINE") (progn (setq allx 0 ally 0 ctr 0 tst 1 ) (while (assoc 10 el) (setq vertex (cdr (assoc 10 el)) ctr (+ ctr 1) x (car vertex) y (cadr vertex) allx (+ allx x) ally (+ ally y) EL (cdr (member (assoc 10 el) el)) ) ) (setq x (/ allx ctr) y (/ ally ctr) pt (list x y) ) (command "text" "j" "mc" pt (* sch 2.5) "0" (rtos areaobj 2 precision) ) ) ) ((eq (cdr (assoc 0 el)) "REGION") (setq reg_centroid (vlax-safearray->list (vlax-variant-value (vla-get-centroid entnamevla) ) ) ) (command "text" "j" "mc" reg_centroid (* sch 2.5) "0" (rtos areaobj 2 precision) ) ) ((eq (cdr (assoc 0 el)) "CIRCLE") (setq cir_center (vlax-safearray->list (vlax-variant-value (vla-get-center entnamevla) ) ) ) (command "text" "j" "mc" cir_center (* sch 2.5) "0" (rtos areaobj 2 precision) ) ) ((eq (cdr (assoc 0 el)) "ELLIPSE") (setq el_center (vlax-safearray->list (vlax-variant-value (vla-get-center entnamevla) ) ) ) (command "text" "j" "mc" el_center (* sch 2.5) "0" (rtos areaobj 2 precision) ) ) ((eq (cdr (assoc 0 el)) "SPLINE") (vla-GetBoundingBox entnamevla 'minPt 'maxPt) (setq blPt (vlax-safearray->list minPt) trPt (vlax-safearray->list maxPt) ) (setq spl_center (mapcar '* '(0.5 0.5 0.5) (mapcar '+ blPt trPt)) ) (command "text" "j" "mc" spl_center (* sch 2.5) "0" (rtos areaobj 2 precision) ) ) ) (setq counter (+ counter 1)) ) ) (alert "\nNO CLOSED POLYLINES/LWPOLYLINES/SPLINES IN YOUR SELECTION" ) ) (reset_var) (princ) ) (prompt "'\n>>>...AreaRon.Lsp is now Loaded, Type 'Arearon' to start command...<<<") (princ) it does not yet exports to excel, i'll try to add it when i have a free time. Quote
vanhuyou Posted June 7, 2025 Posted June 7, 2025 On 2/9/2009 at 8:14 PM, wizman said: here's an update, works now for region, circle,ellipse and and closed spline ;;; CADALYST 07/08 www.cadalyst.com/code ;;; Tip 2292: AreaRon.lsp Area of Closed Polylines (c) 2008 Ronald Maneja (Wizman) ;;; PRODUCES TEXT CONTAINING AREA OF SELECTED CLOSED POLYLINES ;;; AND PUTS THEM IN AREARON LAYER ;;; CREATED BY RON MANEJA 31JAN08 ;;; USER INPUTS: SCALE, POLYLINE SELECTION ;;; ;;; VERSION 1.1 (09FEB09): ADDED AREA FOR REGIONS, SPLINE, CIRCLE & ELLIPSE ;;; (defun C:AREARON (/ allx ally areaobj counter ctr el entity-name entnamevla mysset prec_temp pt reg_centroid temp tst vertex x y oldlayer oldsnap temperr traperror blpt cir_center el_center maxpt minpt spl_center trpt ) (defun set_var () (setvar 'cmdecho 0) (setq oldlayer (getvar "clayer")) (setq oldsnap (getvar "osmode")) (setq temperr *error*) (setq *error* traperror) (setvar "osmode" 0) ) (defun traperror (errmsg) (command nil nil nil) (if (not (member errmsg '("console break" "Function Cancelled")) ) (princ (strcat "\nError: " errmsg)) ) (command "_.undo" "end") (setvar "clayer" oldlayer) (setvar "osmode" oldsnap) (setvar "cmdecho" 1) (princ "\nError Resetting Enviroment ") (setq *error* temperr) ) (defun reset_var () (setq *error* temperr) (setvar "clayer" oldlayer) (setvar "osmode" oldsnap) (command "_.undo" "end") (setvar "cmdecho" 1) ) (vl-load-com) (set_var) (command "_.undo" "be") (if (tblsearch "Layer" "AREARON") (command "._layer" "_thaw" "AREARON" "_on" "AREARON" "_unlock" "AREARON" "_set" "AREARON" "") ;_ closes command (command "._layer" "_make" "AREARON" "_color" 1 "AREARON" "") ;_ closes command ) (if (null sch) (setq sch 1.0) ) (initget 6) (setq temp (getreal (strcat "\nENTER SCALE <" (rtos sch 2 2) ">: " ) ) ) (if temp (setq sch temp) (setq temp sch) ) (if (null precision) (setq precision 1) ) (initget 6) (setq prec_temp (getint (strcat "\nHOW MANY DECIMAL PLACES?: <" (rtos precision 2 2) ">: " ) ) ) (if prec_temp (setq precision prec_temp) (setq prec_temp precision) ) (prompt "\nSELECT CLOSED POLYLINES/SPLINES, REGION, CIRCLE & ELLIPSE:> ") (setq mysset (ssget '((-4 . "<or") (-4 . "<and") (0 . "LWPOLYLINE") (70 . 1) (-4 . "and>") (-4 . "<and") (0 . "SPLINE") (70 . 11) (-4 . "and>") (0 . "REGION") (0 . "CIRCLE") (0 . "ELLIPSE") (-4 . "or>") ) ) counter 0 ) (if mysset (progn (while (< counter (sslength mysset)) (setq entity-name (ssname mysset counter) EL (entget entity-name) entnamevla (vlax-ename->vla-object entity-name) areaobj (vla-get-area entnamevla) ) (cond ((eq (cdr (assoc 0 el)) "LWPOLYLINE") (progn (setq allx 0 ally 0 ctr 0 tst 1 ) (while (assoc 10 el) (setq vertex (cdr (assoc 10 el)) ctr (+ ctr 1) x (car vertex) y (cadr vertex) allx (+ allx x) ally (+ ally y) EL (cdr (member (assoc 10 el) el)) ) ) (setq x (/ allx ctr) y (/ ally ctr) pt (list x y) ) (command "text" "j" "mc" pt (* sch 2.5) "0" (rtos areaobj 2 precision) ) ) ) ((eq (cdr (assoc 0 el)) "REGION") (setq reg_centroid (vlax-safearray->list (vlax-variant-value (vla-get-centroid entnamevla) ) ) ) (command "text" "j" "mc" reg_centroid (* sch 2.5) "0" (rtos areaobj 2 precision) ) ) ((eq (cdr (assoc 0 el)) "CIRCLE") (setq cir_center (vlax-safearray->list (vlax-variant-value (vla-get-center entnamevla) ) ) ) (command "text" "j" "mc" cir_center (* sch 2.5) "0" (rtos areaobj 2 precision) ) ) ((eq (cdr (assoc 0 el)) "ELLIPSE") (setq el_center (vlax-safearray->list (vlax-variant-value (vla-get-center entnamevla) ) ) ) (command "text" "j" "mc" el_center (* sch 2.5) "0" (rtos areaobj 2 precision) ) ) ((eq (cdr (assoc 0 el)) "SPLINE") (vla-GetBoundingBox entnamevla 'minPt 'maxPt) (setq blPt (vlax-safearray->list minPt) trPt (vlax-safearray->list maxPt) ) (setq spl_center (mapcar '* '(0.5 0.5 0.5) (mapcar '+ blPt trPt)) ) (command "text" "j" "mc" spl_center (* sch 2.5) "0" (rtos areaobj 2 precision) ) ) ) (setq counter (+ counter 1)) ) ) (alert "\nNO CLOSED POLYLINES/LWPOLYLINES/SPLINES IN YOUR SELECTION" ) ) (reset_var) (princ) ) (prompt "'\n>>>...AreaRon.Lsp is now Loaded, Type 'Arearon' to start command...<<<") (princ) it does not yet exports to excel, i'll try to add it when i have a free time. Bro can help me change unit mm2 -> m2 Quote
Isaac26a Posted June 7, 2025 Posted June 7, 2025 Just have to insert a line ;;; CADALYST 07/08 www.cadalyst.com/code ;;; Tip 2292: AreaRon.lsp Area of Closed Polylines (c) 2008 Ronald Maneja (Wizman) ;;; PRODUCES TEXT CONTAINING AREA OF SELECTED CLOSED POLYLINES ;;; AND PUTS THEM IN AREARON LAYER ;;; CREATED BY RON MANEJA 31JAN08 ;;; USER INPUTS: SCALE, POLYLINE SELECTION ;;; ;;; VERSION 1.1 (09FEB09): ADDED AREA FOR REGIONS, SPLINE, CIRCLE & ELLIPSE ;;; (defun C:AREARON (/ allx ally areaobj counter ctr el entity-name entnamevla mysset prec_temp pt reg_centroid temp tst vertex x y oldlayer oldsnap temperr traperror blpt cir_center el_center maxpt minpt spl_center trpt ) (defun set_var () (setvar 'cmdecho 0) (setq oldlayer (getvar "clayer")) (setq oldsnap (getvar "osmode")) (setq temperr *error*) (setq *error* traperror) (setvar "osmode" 0) ) (defun traperror (errmsg) (command nil nil nil) (if (not (member errmsg '("console break" "Function Cancelled")) ) (princ (strcat "\nError: " errmsg)) ) (command "_.undo" "end") (setvar "clayer" oldlayer) (setvar "osmode" oldsnap) (setvar "cmdecho" 1) (princ "\nError Resetting Enviroment ") (setq *error* temperr) ) (defun reset_var () (setq *error* temperr) (setvar "clayer" oldlayer) (setvar "osmode" oldsnap) (command "_.undo" "end") (setvar "cmdecho" 1) ) (vl-load-com) (set_var) (command "_.undo" "be") (if (tblsearch "Layer" "AREARON") (command "._layer" "_thaw" "AREARON" "_on" "AREARON" "_unlock" "AREARON" "_set" "AREARON" "") ;_ closes command (command "._layer" "_make" "AREARON" "_color" 1 "AREARON" "") ;_ closes command ) (if (null sch) (setq sch 1.0) ) (initget 6) (setq temp (getreal (strcat "\nENTER SCALE <" (rtos sch 2 2) ">: " ) ) ) (if temp (setq sch temp) (setq temp sch) ) (if (null precision) (setq precision 1) ) (initget 6) (setq prec_temp (getint (strcat "\nHOW MANY DECIMAL PLACES?: <" (rtos precision 2 2) ">: " ) ) ) (if prec_temp (setq precision prec_temp) (setq prec_temp precision) ) (prompt "\nSELECT CLOSED POLYLINES/SPLINES, REGION, CIRCLE & ELLIPSE:> ") (setq mysset (ssget '((-4 . "<or") (-4 . "<and") (0 . "LWPOLYLINE") (70 . 1) (-4 . "and>") (-4 . "<and") (0 . "SPLINE") (70 . 11) (-4 . "and>") (0 . "REGION") (0 . "CIRCLE") (0 . "ELLIPSE") (-4 . "or>") ) ) counter 0 ) (if mysset (progn (while (< counter (sslength mysset)) (setq entity-name (ssname mysset counter) EL (entget entity-name) entnamevla (vlax-ename->vla-object entity-name) areaobj (vla-get-area entnamevla) areaobj (/ areaobj 1000000.) ;;; This line makes mm2 -> m2 ) (cond ((eq (cdr (assoc 0 el)) "LWPOLYLINE") (progn (setq allx 0 ally 0 ctr 0 tst 1 ) (while (assoc 10 el) (setq vertex (cdr (assoc 10 el)) ctr (+ ctr 1) x (car vertex) y (cadr vertex) allx (+ allx x) ally (+ ally y) EL (cdr (member (assoc 10 el) el)) ) ) (setq x (/ allx ctr) y (/ ally ctr) pt (list x y) ) (command "text" "j" "mc" pt (* sch 2.5) "0" (rtos areaobj 2 precision) ) ) ) ((eq (cdr (assoc 0 el)) "REGION") (setq reg_centroid (vlax-safearray->list (vlax-variant-value (vla-get-centroid entnamevla) ) ) ) (command "text" "j" "mc" reg_centroid (* sch 2.5) "0" (rtos areaobj 2 precision) ) ) ((eq (cdr (assoc 0 el)) "CIRCLE") (setq cir_center (vlax-safearray->list (vlax-variant-value (vla-get-center entnamevla) ) ) ) (command "text" "j" "mc" cir_center (* sch 2.5) "0" (rtos areaobj 2 precision) ) ) ((eq (cdr (assoc 0 el)) "ELLIPSE") (setq el_center (vlax-safearray->list (vlax-variant-value (vla-get-center entnamevla) ) ) ) (command "text" "j" "mc" el_center (* sch 2.5) "0" (rtos areaobj 2 precision) ) ) ((eq (cdr (assoc 0 el)) "SPLINE") (vla-GetBoundingBox entnamevla 'minPt 'maxPt) (setq blPt (vlax-safearray->list minPt) trPt (vlax-safearray->list maxPt) ) (setq spl_center (mapcar '* '(0.5 0.5 0.5) (mapcar '+ blPt trPt)) ) (command "text" "j" "mc" spl_center (* sch 2.5) "0" (rtos areaobj 2 precision) ) ) ) (setq counter (+ counter 1)) ) ) (alert "\nNO CLOSED POLYLINES/LWPOLYLINES/SPLINES IN YOUR SELECTION" ) ) (reset_var) (princ) ) (prompt "'\n>>>...AreaRon.Lsp is now Loaded, Type 'Arearon' to start command...<<<") (princ) 1 Quote
