Lisp returns error: Error1: malformed list on input at [read] : File <C:/temp/Contour/dlbl.lsp>
Hi.
I've found this lisp (see attached .lsp file) in this thread:
the lisp return error.
can anyone help me with making this lisp to run?...
many thanks,
Ari.
*let me just add that I don't need the text to be with a background mask,so if the problem is there just show me what to delete...
dlbl.lsp
Edited by aridzv
The issue is caused by the update to the CADTutor forum software removing all instances of "8 )" (without the space) from all code snippets, breaking them.
In this case, change:
(setq code (grread t )
To:
(setq code (grread t 8))
To:
THANKS!!!!!
That was it,problem solved.
Ari.
