X11start Posted April 11, 2021 Posted April 11, 2021 An external software creates me a series of Script files which, once launched, generate a drawing. I have a folder containing the files: P01.scr P02.scr P03.scr ... and I would like to run them in sequence, and then save them as single files: P01.dwg P02.dwg P03.dwg ... I tried with Lee Mac's "ScriptWriter.lsp", but I can't get him to manage Scripts but only DWG. Does someone have a solution? thanks Quote
BIGAL Posted April 11, 2021 Posted April 11, 2021 You have to daisy chain scripts ie last line p01.scr is SCRIPT p02. Should work not tested. I would look more at a lisp solution. Can you describe what your scripts are doing. Quote
X11start Posted April 12, 2021 Author Posted April 12, 2021 (edited) The scripts create a new drawing, starting from the DWT "TQuadro.dwt"; therefore it's not possible to save empty DWGs called P01 - P02 etc. but the idea of modifying the scripts to recall other "daisy" scripts is interesting! I found a (very long!) Way, using a DOS batch file: for %% f in (* .scr) do "C: \ Program Files \ Autodesk \ AutoCAD 2019 - Italiano \ acad.exe" / nologo / b %% f (This file called "SCRIPT.BAT") Basically I scroll all the SCR files of the current folder and for each one I open Autocad and execute the script (with the / b option). / nologo I use it to speed up opening and not display the Autocad logo. To every file script I must be added: _saveas <- This blank line use for ENTER P01 _quit This thing can be done manually or with a bat, doing a "COPY >" (to concatenate at the bottom what I need) and FOR ... DO ... etc but I'm still working on it, because the text P01 obviously has to change with every file. Concluding: this is not a "definitive" solution as for each Script it comes: - Open Autocad - Run the script - Save file - Closed Autocad ... in short, it takes a lot of time; but you can launch it during your lunch break! I attach the dwg that is created by the script (P01.dwg), the script (P01.scr) and my Batch file (SCRIPT.BAT) Many thanks for your tip! P01.dwg P01.scr SCRIPT.BAT Edited April 12, 2021 by X11start Quote
maratovich Posted April 12, 2021 Posted April 12, 2021 Maybe this will help you - AutoRunLisp There is a script execution tab. Quote
BIGAL Posted April 13, 2021 Posted April 13, 2021 (edited) You should try using Aeccoreconsole if your going to continue using a BAT file approach works in background no opening of Acad. Nothing to do with you but my latest Win 10 or Norton upgrade has banned opening .scr files so just a comment posters to the forum may have to do "myscript.scr.txt" to get around it. It did actually download Unconfirmed 438070.crdownload Had a quick look at the script if the same for each dwg why not just insert a dwg that has all those items pre saved, save to 0,0 explode once, then -purge Blocks dwgnameinserted or make a new Dwg or DWT. Edited April 13, 2021 by BIGAL Quote
X11start Posted April 13, 2021 Author Posted April 13, 2021 I attached the SCR and the DWG that was obtained, but I did not attach the DWT: it contained the company's data and I did not want to violate the copyright. Each SCR creates the corresponding DWG starting from the DWT (TQuadro.dwt) I think the solution is to add instructions to the bottom of each SCR to launch the next SCR (as you suggested in your first post). To do this, if I can't get it with a bat, I'll try to make an exe with QB64. As soon as I manage to create the EXE, I share it on this post: so it could be useful to others. Many thanks for all the answers! Quote
BIGAL Posted April 14, 2021 Posted April 14, 2021 Had a look at your dwg so you have a program somewhere that creates the script ? Is it a VBA in excel, could be ported to Autocad, alternatively if excel it can draw in Autocad no need for script. Quote
X11start Posted April 14, 2021 Author Posted April 14, 2021 The scripts are generated by an external program (perhaps written in VB) which gives us a supplier to calculate the precast panels using their elements. So I can't change it. I can only find the fastest way to turn it into DWG. Just a tip ... in script file is it possible to use "close" command? I tried putting it after saving the DWG (P01). I running the next script ... (P02) but the script is terminated when it find CLOSE. ex. .... start script ... ... ... end script _qsave P01 _close script P02 The solution would be to not use the "Close" command .... but I can't load 100 or 200 dwg without closing any! So (if there is no other solution), I believe I will run the scripts in batches of 10. Quote
steven-g Posted April 14, 2021 Posted April 14, 2021 Do you have any control over the script writing? rather than generate separate scripts can you arrange that the program just creates one large script similar to the following. filedia 0 circle 0,0 10 saveas circle.dwg erase all rectangle 0,0 10,10 saveas rectangle.dwg erase all line 0,0 10,0 saveas line.dwg filedia 1 close This creates the drawing content, saves the file, then deletes everything and creates the next load of drawing content. This way there is no need to keep opening and closing drawings (which as you point out kills the script) Quote
BIGAL Posted April 15, 2021 Posted April 15, 2021 Not sure had a look at posted script and never had a problem with open close have used this on like 100 dwgs to make slides but it was one script. As suggested if doing a Bat approach use Accorconsole and open each script seperately. Could use a lisp to write the bat file to suit the number of scripts to be processed. Then maybe issue the "shell" command and run the Bat which will run in background. Quote
X11start Posted April 15, 2021 Author Posted April 15, 2021 Many thanks for all the suggestions - I'm going to experiment this weekend! Quote
X11start Posted April 20, 2021 Author Posted April 20, 2021 It wasn't easy but I found a solution ... in DOS! I created 2 BAT files to save in the folder that contains the SCR files to be processed. I preferred try to use BAT files and not use Autolisp .... to be able to do the job also using Autocad LT. START.BAT (is simple txt file renamed .bat): @echo off REM REM At the end of each file Name File.scr add save command REM and renames them aaaNamefile.scr REM echo 0 > count.txt for %%f in (*.scr) do ( echo FILEDIA 0 _saveas %%f FILEDIA 1 _quit > count.txt type > aaa%%f %%f count.txt ) Then the second BAT is launched ... SCRIPT.BAT is .... @echo off REM REM Run autocad for each "aaaNamefile.scr" file in the directory and create the DWG files REM for %%f in (aaa*.scr) do "C:\Program Files\Autodesk\AutoCAD LT 2019\acadlt.exe" /nologo /b /six %%f echo END .... this's how DWGs are created! Quote
