mhupp Posted April 21, 2021 Posted April 21, 2021 This use to work properly but now the nomutt variable doesn't suppress the dimlinear command. ;;------------------------------------------------------------------------------------------------------------;; ;; Create Overall Dimension for Everything Selected. (defun C:ODIM (/ SS UL LL UR LR ML MB oLL oUR) (if (ssget "_I") ; if there are preselected objects [= Implied selection] (sssetfirst nil (setq SS (ssget "_I"))) (setq SS (ssget)) ) (if (/= SS nil) (progn (BBox) ; overall bounding box lisp outputs LL UR points (setq UL (list (car LL) (cadr UR)) LR (list (car UR) (cadr LL)) ML (polar LL 1.5708 (/ (distance LL UL) 2)) MB (polar LL 0 (/ (distance LL LR) 2)) ) (setvar 'nomutt 1) (if (tblsearch "LAYER" "Dimensions") (setvar 'clayer "Dimensions") (vl-cmdf "-Layer" "M" "Dimensions" "C" "7" "" "") ) (vl-cmdf "_.Dimlinear" "_non" LL "_non" UL "_non" (polar ML 3.14159 1)) (vl-cmdf "_.Dimlinear" "_non" LL "_non" LR "_non" (polar MB 4.71239 1)) (setvar 'nomutt 0) ) ) (princ) ) must have change a system variable somewhere any ideas? Also tried expert 5 still showing up. : _.Dimlinear Origin of first extension line <Select entity>:_non Origin of second extension line:_non [Angle/Text/Horizontal/Vertical/Rotated]:_non Dimension text: = 22.005 : _.Dimlinear Origin of first extension line <Select entity>:_non Origin of second extension line:_non [Angle/Text/Horizontal/Vertical/Rotated]:_non Dimension text: = 15.885 Quote
rlx Posted April 21, 2021 Posted April 21, 2021 (edited) cmdecho? or create dim as shown in official help documentation : http://help.autodesk.com/view/ACD/2015/ENU/?guid=GUID-9F5CE147-3787-4DD9-8028-8E89BF02A357 (vl-load-com) (defun c:Example_AddDimAligned() ;; This example creates an aligned dimension in model space. (setq acadObj (vlax-get-acad-object)) (setq doc (vla-get-ActiveDocument acadObj)) ;; Define the dimension (setq point1 (vlax-3d-point 5 5 0) point2 (vlax-3d-point 10 5 0) location (vlax-3d-point 5 7 0)) ;; Create an aligned dimension object in model space (setq modelSpace (vla-get-ModelSpace doc)) (setq dimObj (vla-AddDimAligned modelSpace point1 point2 location)) (vla-ZoomAll acadObj) ) Edited April 21, 2021 by rlx Quote
mhupp Posted April 21, 2021 Author Posted April 21, 2021 (edited) I have a start and end macros that handle cmdecho along with some other system variables. i took them out but looks like i left in (bbox) ill try the vla stuff tomorrow. Edited April 21, 2021 by mhupp Quote
mhupp Posted April 22, 2021 Author Posted April 22, 2021 14 hours ago, mhupp said: and end macros that handle cmdecho along with some other system variables. LOL answered my own question had a dimstyle command call right after nomutt is set to 1 that was turning it back to 0 in the end macro. much cleaner now : ODIM Select entities: Opposite Corner: Entities in set: 1 Select entities: Quote
