plecs Posted April 23, 2021 Posted April 23, 2021 Hello all. I have a problem and I don't know how to solve it I have a list '(("0" "1" "red") ("1" "1" "red") ("2" "1" "red") ("4" "1" "red") ("0" "2" "blue") ("1" "2" "blue") ("2" "4" "blue") ("4" "5" "blue") ("15" "2" "yellow") ("16" "2" "yellow") ("21" "4" "yellow") ("40" "5" "yellow")) and I would like to separate them into several lists ex: (list1 '(("0" "1" "red") ("1" "1" "red") ("2" "1" "red") ("4" "1" "red"))) (list2 '(("0" "2" "blue") ("1" "2" "blue") ("2" "4" "blue") ("4" "5" "blue"))) (list3 '(("15" "2" "yellow") ("16" "2" "yellow") ("21" "4" "yellow") ("40" "5" "yellow"))) how would it be possible to do this with a lisp routine thank you in advance Quote
David Bethel Posted April 23, 2021 Posted April 23, 2021 If I understand correctly, this could be 1 way to approach it: (setq lst '(("0" "1" "red") ("1" "1" "red") ("2" "1" "red") ("4" "1" "red") ("0" "2" "blue") ("1" "2" "blue") ("2" "4" "blue") ("4" "5" "blue") ("15" "2" "yellow") ("16" "2" "yellow") ("21" "4" "yellow") ("40" "5" "yellow"))) (setq red nil blue nil yellow nil) (foreach l lst (set (read (last l)) (cons l (eval (read (last l)))))) One of the problems with (set) is figuring out how to localize the return lists Good luck -David Quote
rlx Posted April 23, 2021 Posted April 23, 2021 david beat me to it... (defun tst ( / m lst l1 l2 l3 l4) (vl-load-com) (defun m (l v) (vl-remove-if-not '(lambda (x)(member v x)) l)) (setq lst '(("0" "1" "red") ("1" "1" "red") ("2" "1" "red") ("4" "1" "red") ("0" "2" "blue") ("1" "2" "blue") ("2" "4" "blue") ("4" "5" "blue") ("15" "2" "yellow") ("16" "2" "yellow") ("21" "4" "yellow") ("40" "5" "yellow"))) (setq l1 (m lst "red") l2 (m lst "blue") l3 (m lst "yellow")) (princ (strcat "\nList Red = " (vl-princ-to-string l1))) (princ (strcat "\nList Blue = " (vl-princ-to-string l2))) (princ (strcat "\nList Yellow = " (vl-princ-to-string l3))) (princ) ) Quote
BIGAL Posted April 23, 2021 Posted April 23, 2021 Like david as you have a sorted list can use the set to make lst1 lst2 etc looking at is the next value color the same if yes then add it to list, this way can have as many colors as you want, maybe make varaible lstred. I need some time to think about it. Quote
rlx Posted April 23, 2021 Posted April 23, 2021 (edited) If you worry about localizing then don't and create assoc list like : ( ("red" . (( "0" "1")( "1" "1")( "2" "1")( "4" "1"))) ("blue" . (( "0" "2")( "1" "2")( "2" "4")( "4" "5"))) ("yellow" . (("15" "2")("16" "2")("21" "4")("40" "5"))) ) ;;; like this : (setq lst '(("0" "1" "red")("1" "1" "red")("2" "1" "red")("4" "1" "red") ("0" "2" "blue")("1" "2" "blue")("2" "4" "blue")("4" "5" "blue") ("15" "2" "yellow")("16" "2" "yellow")("21" "4" "yellow")("40" "5" "yellow"))) (defun t1 ( l / c r) (foreach x l (if (assoc (setq c (last x)) r) (setq r (subst (cons c (cons x (cdr (assoc c r))))(assoc c r) r))(setq r (cons (cons c (list x)) r))))(reverse r)) (defun t2 ( l / c r) (foreach x l (if (assoc (setq c (last x)) r) (setq r (subst (cons c (cons (reverse (cdr (reverse x))) (cdr (assoc c r)))) (assoc c r) r)) (setq r (cons (cons c (list (reverse (cdr (reverse x))))) r)))) (reverse r)) (setq l1 (t1 lst)) (setq l2 (t2 lst)) Edited April 23, 2021 by rlx Quote
David Bethel Posted April 25, 2021 Posted April 25, 2021 On 4/23/2021 at 6:03 PM, BIGAL said: I need some time to think about it. I've played with recording the atoms-family as the first call in a routine. Then compare that to a closing atoms-family for new atoms. maybe a (boundp) test Nothing ever jumped out as a foolproof method. So I use (set) sparingly in this scenario for public snippets A single session in-house call is useful some times I looked and was surprised to have 470 .lsp files that includes (set (read I would not have guessed I use it so much !!! Regards -David Quote
