I stumbled upon this routine by Ronjonp. It isolates an xref layer and unisolates it. I was wondering if i selected an xref layer entity and a dimension within modelspace, could it isolate both layers?
;;; AUTHOR
;;; Copyright© 2009 Ron Perez (ronperez AT gmail dot com)
;;; Isolates selected object layers (similar to LAYISO express tool but will work with nested xref layers)
;;; ISO to invoke...UNISO to restore layer settings (saved in global variable *rjp-savedlayersettings*)
(defun c:iso (/			rjp-dxf		  rjp-freezeallbutselected
	      rjp-getnested	rjp-getlayers	  e
	      out		rjp-nentsel	  rjp-undobegin
	      rjp-undoend
  (vl-load-com)
  (if *rjp-savedlayersettings*
    (c:uniso)
  (defun rjp-dxf (code ent) (cdr (assoc code (entget ent))))
  (defun rjp-getlayers (ent) (tblobjname "layer" (rjp-dxf 8 ent)))
  (defun rjp-freezeallbutselected (lst / lay out)
    (while (setq lay (tblnext "layer" (not lay)))
      (setq out (cons (tblobjname "layer" (cdr (assoc 2 lay))) out))
    (mapcar '(lambda (x) (vl-catch-all-apply 'setvar (list "clayer" (rjp-dxf 2 x))))
	    lst
    (mapcar '(lambda (x) (vl-catch-all-apply 'vla-put-freeze (list x :vlax-true)))
	    (setq
	      out (mapcar
		    'vlax-ename->vla-object
		    (vl-remove-if
		      '(lambda (x)
			 (or (vl-position x lst)
			     (= (vla-get-freeze (vlax-ename->vla-object x)) :vlax-true)
		      out
    out
  (defun rjp-nentsel (msg / p out)
    (setvar "ErrNo" 0)
    (while
      (not
	(cond
	  ((and (null (setq p (nentsel (strcat "\n" msg)))) (/= 52 (getvar 'errno)))
	   (prompt "\nSelection missed please try again...")
	  ((null p) t)
	  ((progn (setq out p)))
    out
  (defun rjp-undobegin (/ doc)
    (setq doc (vla-get-activedocument (vlax-get-acad-object)))
    (vla-endundomark doc)
    (vla-startundomark doc)
  (defun rjp-undoend (/ doc)
  (defun rjp-getnested (ent)
    (if	ent
      (if (cadddr ent)
	(append (list (car ent)) (cadddr ent))
	(list (car ent))
  (while (setq e (rjp-nentsel "Select object(s) to isolate layers: "))
    (setq out (cons (rjp-getnested e) out))
    (princ (apply 'strcat
		  (mapcar '(lambda (x) (strcat (rjp-dxf 8 x) "  ")) (rjp-getnested e))
  (if (setq out (apply 'append out))
      (rjp-undobegin)
      (setq *rjp-savedlayersettings*
	     (rjp-freezeallbutselected
	       (mapcar 'rjp-getlayers out)
      (vla-regen (vla-get-activedocument (vlax-get-acad-object)) acactiveviewport)
      (rjp-undoend)
      (defun c:uniso (/)
	    (mapcar
	      '(lambda (x) (vl-catch-all-apply 'vla-put-freeze (list x :vlax-false)))
		       acactiveviewport
	    (setq *rjp-savedlayersettings* nil)
	  (princ "\nNo layer settings saved...")
    (princ "\nNothing selected...")
That's a blast from the past 😳  ... I found this in my slew of routines, give it a try.
;;; AUTHOR
;;; Copyright© 2007 Ron Perez
(defun c:nlayiso (/ llst x n)
  (and *frzlyrs* (c:nlayuniso))
  (while (setq x (nentsel "\nSelect objects on the layer(s) to be isolated: "))
    (foreach z (append (list (car x)) (cadddr x))
      (setq n (cdr (assoc 8 (entget z))))
      (or (member n llst) (progn (setq llst (cons n llst)) (princ (strcat "\n" n))))
  (if llst
      (vlax-for	x (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))
	(or (member (vla-get-name x) llst)
	    (progn (setq *frzlyrs* (cons (cons x (vla-get-freeze x)) *frzlyrs*))
		   (vl-catch-all-error-p (vl-catch-all-apply 'vla-put-freeze (list x :vlax-true)))
      (defun c:nlayuniso (/)
	(if *frzlyrs*
	  (foreach x *frzlyrs*
	    (vl-catch-all-error-p (vl-catch-all-apply 'vla-put-freeze (list (car x) (cdr x))))
	(command "._regen")
	(setq *frzlyrs* nil)
Edited by ronjonp
Ron! So AWESOME! Sorry to bring up the past;) Thank you for sharing that! Works great.
no more racking my head through all the layers!
Edited by rcb007
Glad to help 🍻
